Thread: Series IIA SWB Auxiliary battery - how and where
    Nov 2014
    Melbourne, Mount Waverley
    I am planning on fitting an auxiliary battery but all my online searches to date have failed to find even a single image of such an installation. Plenty of "Discovery Series 2" but no original Series II; "a" or otherwise.
    Someone must have done this job?
    I also plan on fitting a second fuel tank. This will go under the passenger seat so installation of the battery in that position is excluded.
    Any thoughts, advice, pictures . . . . . music ?
    Near Seven Hills, Sydney
    Stick it in the tub in a ventilated battery box, not many other options around if you have a second fuel tank.
    Ipswich QLD.
    My S III had a battery box for 2nd battery mounted between the bumper and the grill when I got it, I haven't had a need for a second battery on that one so took the box off. The curved infill that usually sits in that position has been replaced with a flat piece of aluminium.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Nov 2014
    Front mounted battery box
    Quote Originally Posted by Killer View Post
    Cheers, Mick.
    Mick. Any trouble with air flow onto radiator? Do you have any photos of the box or the installation?
    Damian
    Nov 2014
    Ventilating battery
    Quote Originally Posted by isuzutoo-eh View Post
    Do I need to ventilate to a point outside the cab and tub, i.e. truly outside?
    Nundle
    Quote Originally Posted by damiane View Post
    In short, no.
    On a S11A exmil I had once , we had a second battery in the tub and did a lot of k's with it there with no issues at all.
    Numpty
    REMLR No 143
    Ipswich QLD.
    Damian
    Like I said, I never used the vehicle with the battery in that position, so I couldn't say for sure about it restricting air flow. It was off to one side against the chassis, so away from the main part of the grille on a series III, although a series IIa could be a different story. Sorry, I don't have photos of the installation.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
