Results 1 to 10 of 12
Thread: Problems with my 02 landrover discovery series 2td5
    Daveymac Guest
    Hi guys
    I recently bought an auto 02 landrover discovery td5 from a 2nd hand car dealer. I am no way mechanically inclined, I'm a carpenter by trade. I bought it because they use them back in Ireland for off roading and I was told they are a great car. Well long story short I had it 5 days when the oil light came on, had to get it towed to a mechanic recommended by my brother who called me back with a list of things that were wrong with it. There was something with the transmission, the coolant tank exploded and there were a lot of oil leaks. So I told him to go ahead and do the repairs and a full service on it seeing as it was due anyway. It came to 1450 (which he told me it would be in around that figure) so I was prepared. When I picked it up I asked him what he thought of them he said he had one for 5 years and nothing but oil leaks as they get older and they are british built so are not able for the heat over here. I pulled back into my yard this morning and noticed a small drip from under the engine and again at the shop. My questions are: did I just get a bad one? Should I just save myself hassle and sell it? Is there anything I can do to fix this? I'm planning to do a bit of travelling and camping but now I'm afraid il be out in the bush somewhere and end up breaking down. Any advice would be much appreciated and again I'm not a mechanic I just really like land rovers. Thanks for reading
    Jun 2013
    Augusta WA
    The mechanic is not correct, with a D2 TD5 you have some good German engineering that is quite happy with the heat here. The problem is more likely buying one from a 2nd hand car dealer without a reliable service history and an unloved vehicle. The TD5 is a great car that will only let people down if not looked after by preventative maintenance. What is the mileage and is there any history? Mine has done 415K and is still driving like new so don't despair.
    Nick
    May 2003
    On The Road
    I wonder what parts of a Td5 are actually german designed,,
    certainly not the engine, maybe the gearbox?
    probably some of the computers,,
    Daveymac, buying a 12 year old car and expecting it to function like new is a bit silly,,
    have you read this?
    http://www.aulro.com/afvb/discovery-...02-2004-a.html
    lots of TD5's running mega miles around here,, but they are owned by Land Rover people
    darwin
    The first thing you could do is use a mechanic that likes land rovers,Take it to them for a checkup.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Avoca Beach
    IMHO it is rubbish to suggest the cooling systems are not sufficient.
    My 2002 with 168KK on it still has the original radiator which I reverse flushed when I replaced all of the hoses, and it runs at thermostat opening temp of 82=84 C most of the time. Up the Alpine way towing a 900Kg camper trailer it has ONCE touched 103 C. This is the highest and steepest continuous climb I have found in OZ. In the Kimberley in 36=38C it ran on 84 C.
    I have to cross fingers here but mine does not leak (much) at present, as I had the transfer case deleaked and I recently replaced the Rocker cover gasket. But I have to admit that they do have a number of leak prone components. Really leaks are a part of an old car. Show me a supermarket parking lot where every space doesn't have oil drops or a dried pool.
    Really , 12 year old cars are coming into the category of "owner enthusiast". If your car has 200KK or more then you have to expect failures of such things as starter motors , alternators, window lifts etc.
    One of the good things about LRs , is the AULRO forum where there is advice on how to fix most things cheaply, and preventative maintenance is the key. EG did your mechanic replace the "hidden hose"? If not you should have it done, and change all the hoses for that matter.
    If you have a problem or feel something unusual is happening , ask on here.
    Regards Philip A
    Australia
    Yeah, nah....(territory lingo)
    The mechanic is wrong.
    There is no shortfall in the cooling systems for the D2,
    There are a few well documented issues a D2 can suffer, which should have been sorted in any well maintained vehicle , never to return again,
    As for leaks etc it's caused by wear and tear then not maintaining the vehicle, it applies to all makes. That's why cars devalue and get cheaper over time and eventually end up on the tip.
    I'd be concerned about the cause of oil light come on.
    Jun 2013
    Augusta WA
    You are correct Pedro The Swift,
    The T5 engine is Land Rover designed, originally called the Storm engine and was the only LR engine retained by BMW for any new products.
    Nick
    Jul 2014
    west of Transylvania
    Mine is on 250K kms and it gets the worst from all, alternatively down to -25*C in the winter and up to +45*C by summer, took care of it the best i could, it's dry like a bone under it and runs like a dream, find a proper mechanic, IMO you was ripped off cos for that money it should at least not leak at all, gaskets and seals are cheap and for such labour cost IMO they should have replaced them all with gearbox off... these cars were sold on the South-African market too and i didnt hear such enormity that they can't bear the heat
    Daveymac Guest
    Angry
    Hey guys sorry for the late reply and thanks for all yours I'm still trying to figure out how to use forums sorry .. It has 170k on the clock .. I called the guy I bought it from today told him it broke down after 6 days and I got it towed to a recommended mechanic and he said (the dealer) well your problem isn't with me then .. I called the mechanic back told him the story he said he would take it off me drive it a few days and do up a car report on it for me .. Guys I spent every cent I had on this car .. Is there anyway back from it because this week the steering is gone very heavy and a few times iv put it into reverse and accelerate it doesn't move and the same with when I put it in drive .. (And no the handbrake isn't on &#128547 even if I could get my money back and buy one somewhere else because I feel really screwed over here paying out nearly over 8 grand in total and it's still sitting in the driveway ..
    ashhhhh Guest
    I fear you're not going to have any option but to repair or sell or mate.
    As much as it sucks, the car is you're problem now.
    I'm not having a dig but if you had no "repair" fund then you should have shopped very, very carefully.
