Thread: Power Steering Fluid
    Jul 2003
    CJ has just purchased a power steering unit from a wrecked Td5 Defender to replace the one on his County. (Those of you who have been to LVS will know the donor xtreme :wink: )
    John reckons that the fluid was more like hydraulic fluid than the usual Dextron III stuff.
    What is the standard spec for this unit?
    Mahn England
    Ex 300Tdi Disco:
    Toowoomba QLD.
    ATF Dexron IID, or III
    Texaco cold climate PAS fluid 14315
    Cheers.
    NSW far north coast
    As disconut said, Caltex/Texaco Cold Climate PAS 14315 is the factory fill (green colour)
    It's a very good power steering fluid, and I've found it much better than a (mineral) Dex III ATF (Fuchs ATF 4000)
    Currently running Castrol Transmax Z (full synth, Dex III ATF, also green in colour) which has given me better steering feel than the Fuchs fluid had (was lighter), but I reckon the Caltex fluid is better in really cold weather, but I suspect the Transmax Z will be much better off road in high load/temp situations. The Castrol fluid was recommended to me by a fleet truck operator who reckons it's unbeatable in large truck and bus auto trannys.
    Toowoomba QLD.
    I ran Transmax Z in my DII auto and power steering. It made a big difference to the auto. Very smooth.
    Trev.
    May 2002
    Sydney, Australia
    Running Castrol Dexron III ATF in mine also - the red stuff
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
