Results 1 to 10 of 28
Thread: LR Rims & Control Rider Suspension - the saga continues - arrrrgh
    Oct 2011
    Fremantle WA
    I have received some valuable feedback from those taking the time to comment on my previous threads over the last 6 months trying to fit LR alloys to our impending new superannuation depleter/caravan. Many grateful thanks to all contributors.
    After being told D2 alloys (to match my D2a Dan) wont fit (rim centre too small), it eventually transpired that RRC/D1/Defender should work. So I express freighted a specially bought good ex Defender set with tyres from Freo to Melbourne.
    Hadn't heard anything for almost 2 months, until initially being told (not until after us enquiring AFTER due delivery date as to what was happening generally) that the guy in Melb who fits the special front veranda was on holidays and was not due back until 2 weeks after our ETA.
    Then, a couple of days a go, a bombshell - they now claim they can't fit the standard Defender alloys to their Control Rider stub axles and I would have to select a set of rims from their standard range and further they would have to be 5 stud (presumably all at my cost) - YEAH, RIGHT.
    No reasons or explanation given, so I'm following that up first, but I'm highly suspicious to say the least.
    I'm keeping my powder dry, but am expecting the involvement of consumer affairs or similar in some form for specific performance if they don't get their act together. Don't you just love interstate transactions.
    At 3.5T for the van, I can't afford to stuff up on the rims. My gut feel is I may end up with D1 steelies or using a set of old RRC 15" alloys I had other plans for - on the assumption that D2 steelies wont fit - I could not be that lucky/them that stupid could I?
    They say the van is ready apart from sorting rims. Any other brilliant ideas?
    I feel for the majority of honest, hard working Australians, but why are their efforts ruined by so many stupid customer related stuffups and giving the place a bad name. Maybe I have to join the "propensity for buying faulty goods group!!!!
    Stage 1 of rant over, but watch this space as I hopefully recover from my 2nd total knee replacement op last week.
    Bacchus Marsh Vic.
    Ye old double post syndrome
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Bacchus Marsh Vic.
    Are they using a standard Al-Ko brake drum with thier suspension?
    I've fitted Defender alloy rims to 10" duel bearing drums.
    To do it we had to have a slip ring machined to fit the rims and the drum was machined to suit.
    I also had the correct studs fitted so the Land Rover nuts are used.
    AL-KO Electric Drum Brakes
    3/4 of the way down this page is interesting...
    http://www.alko.com.au/vehicle-techn...c-brake-drums/
    Cheers, Kyle
    The Good Oil.
    Oct 2011
    Fremantle WA
    Thanks Kyle - interesting, especially as I specified 3.5T max (which I guess is 2.0 or 2.5T per axle) AND 12" electric brakes. I'll keep your info on hand until they respond to my questions. Cheers
    Mar 2014
    Romsey Country Vic
    In my experience , it is problematic to fit or hubs as al-Ko will de-rate the load capacity .
    3.5 t is a big van - generally to fit lr hubs they will use slimline bearings and a max cap of 600kg a hub , the hubs will need to be machined down . So , less "meat"
    Or use parallel bearings which can be rated a lot higher , but the studs n nuts will need to be genuine .
    If it were me and what I recommend to my customers is -
    " go with Toyota or Nissan 5 or 6 stud , they are standard , parts are easily replaced if required , ask at Mt dare for a Land Rover hub or stud/nut and it's a long wait "
    No offence but there is a reason why it's done that way , carry extra tyre carcasses if required , don't believe the hype on matching wheels etc - from a resale perspective your market is exceptionally limited .
    Except to aulro members of course !
    Take all of the above with a grain of salt if you disagree .
    Read your post again ,
    Could be the centre bore is an issue .
    Ask some questions ,
    Are the wheels load rated ? What is it .(liability)
    Which bearing sets are they using al-Ko use good jap or us bearings - the ones you need will suit a 65mm axle
    Could be a stud issue , size and spacing - again liability .
    Truthfully will you be towing a 3.5 t behemoth "off road " it will be a big unit - like towing a block of flats ��
    South Sydney
    I'm curious to know what the issue is.
    Defender alloys EASILY fit over all the Alko hubs, including parallel bearings.
    I am going to assume they've stuffed up and made the axles too narrow (to suit toyota offset) and have decided that's your problem...
    Mar 2014
    Romsey Country Vic
    Ahhhh mr lr , an option I hadn't considered .
    A good point , well made , add that one to the question list .
    Perth WA 6149
    I'd echo Rex's and Will's comments.
    Unless there is a specific reason (like a defender becoming the tug in the forward planning) then if D2 rims don't fit then go for the most common option with respect to stud patterns.
    But having been spannered by offset myself when changing the rims on my trailer and having to go for a longer axle, I think Will may be on the money.
    I also has a similar problem when the trailer was originally built. They forgot to fit wider guards and when I went to pick it up the wheels were proud of the mud guards. A small discussion ensued and the end result was they had to build me another trailer and sell first with narrow rims.
    Steve
    Oct 2011
    Fremantle WA
    Thanks for all the comments. I too think they have well and truly stuffed up unless their most recent comments are valid as copied below. The LR Def alloys do have a smaller centre than 124 mm, albeit being some distance from the stub axle/brakes - about 90mm ? from dim memory.
    At the end of the day, it's their problem to fix, and ironically I'm in to hurry to take possession following my knee replacement op!! I might have to prevail on one of the many Melb aurlo gurus to straighten them out - a bit far to walk from here!
    "The main reason why the wheel won't fit, is the snout on our hub drum is 93mm from the face to the end of the grease cap.
    Now when we go to fit the hub to the wheel, we have to knock out the centre cap of the wheel for the grease cap to protrude through.
    When doing that the grease cap then fouls on the centre hole of the wheel, so the centre hole of the wheel has to be machined bigger.
    If the customer wants to make the centre hole bigger that's fine, but I'm not going to tamper with that. And I don't think you guys will either.
    Secondly, we have to use the melb tr. 2 piece hub drum to do the stud pattern, which means you ( GnS ) have to make the control rider susp with these drums. Which means different stub axles as well.
    Also the Land rover wheels come in 2 offsets 1, 33mm positive and 2, 57mm positive. When speaking with Salv Monday he said you make the susp to suit a 0 offset wheel."
    I've told them that worst case scenario, I can access a set of LR D1/RRC/Defender 16" steelies with 124mm centre hole, or a set of RRC aftermarket 15" alloys also with 124mm centre hole but unknown offset. Not the best look though.
    The van will actually be under 3T loaded, but registered for 3.5T just in case
    Bacchus Marsh Vic.
    Are they using Al-Ko hubs or their own in house drum?
    I'll slip you a PM and maybe we can chat on the phone about it.
    Cheers, Kyle
    The Good Oil.
