Results 1 to 8 of 8
Thread: Brakes
    Sep 2009
    Broken Hill
    Brakes
    Is it worth while upgrading the brakes on an 86 or 88 inch to those used on the 107 and 109 inch?
    JDNSW's Avatar
    Depends on your attitude to keeping it original. For normal use the the 86/88 brakes are "adequate", bearing in mind the power/weight ratio and loaded weight of the Series 1.
    Certainly, long wheelbase brakes (I would use 2a brakes) will perform better, but consider the difficulty of getting a suitable master cylinder. (I assume the one you have is functional or repairable). And the lwb brakes have a reputation of being more difficult to bleed.
    Dec 2015
    I have just ordered a new master cylinder for my 86" but went back to the UK for it, 50 quid delivered. I t seems like that all models of master cylinder are available for a similar price.
    Narre Warren South
    Quote Originally Posted by Jcrowe69 View Post
    An 86" master cylinder for 50GBP delivered ?
    Is it the original 3 bolt master cylinder that was fitted to the Series I ? You can change to a 2 bolt from a Series II and kits are available to do this.
    The original looks like this (this one's a pattern one for a Minerva).
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2015
    Hi Colin,
    It's the two hole flange type as I couldn't find a correct three hole flange one, do you have a contact or supplier where I can get the correct unit as I was really after one?
    This what I bought
    Bearmach Land Rover Series 2 & 2a SWB 88" Brake Master Cylinder - 520849 | eBay
    Cheers Jason
    Narre Warren South
    Hi Colin,
    This what I bought
    Cheers Jason
    Unfortunately they are like rocking horse droppings.
    Wrinklearthur put me onto the fact that the Minerva master cylinder is identical (it would be as it's basically a Series I), someone on Ebay in Germany had a number of them for sale a while ago.
    The alternative is to get your old one (if you have it) re-sleeved.
    Here is a kit with all the parts needed to fit the later master cylinder Land Rover Series One Brake Parts Page 3 (scroll down).
    The kit saves you drilling a hole in the outrigger.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2015
    I did a lot of Googleing this morning and came across these guys in India, I sent them an email and we'll what comes back. Initially dubious but if the quality is good it might be a good source for these bits.....
    [ame]http://www.brakesofindia.com/European%201/LAND-ROVER.pdf[/ame]
    Jason
    Sep 2009
    Broken Hill
    Good discussion guys, I was only asking aout the 107 / 109 brakes as I have the bits, but I think I may go with the original 10 inch and I really like the conversion kit for the series 2 master cylinder.
