Results 1 to 10 of 40
Thread: D4 - Swapping standard lights to signature lights
    Dec 2014
    Seaholme
    Hi
    Just wondering if anyone has changed over the standard D4 lights to the signature LED lights at all?
    Mar 2007
    South Arm, Tasmania
    I thought all D4's had "signature" LED lights - I've never seen one without them.
    Sure you aren't referring to the difference between the older style of D4 headlights (say 2012) and the newer model's lights (2014 / 2015) ???
    Cheers .........
    BMKAL
    Mar 2015
    SE and HSE have them as standard. TDV6 comes with a single yellow globe that you can change to white but I havent found any updates to the DRL on the SE and HSE models but would love to
    Aug 2015
    Coolamon, NSW
    The early D4 without xenon don't have the LED signature lights
    - Justin
    Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
    Moved into MY12 L322 4.4 TDV8 Autobiography
    VK2HFJ
    So back on topic.
    Yes you can upgrade to Xenon headlights with the Signature lights.
    You then need to edit the CCF to make it all work (easy) using something like the IID tool.
    Oct 2015
    BRISBANE, Au
    So back on topic.
    So the wiring harness plugs straight in?
    NSW SW Slopes
    The standard bi-xenons use the same harness as the halogens but the adaptive bi-xenons require their own control module.
    Oct 2014
    So back on topic.
    So Tombie have you managed to figure out the CCF changes that stumped Kev (Celtoid) in this thread?
    http://www.aulro.com/afvb/d3-d4-rrs/...lation-13.html
    He got close but seemingly not all CCF settings were discovered.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Williams West Aust
    Could be worth talking to Cambo351.It seems he has entered the inner sanctum.
    http://www.aulro.com/afvb/communicat...4-rrs-etc.html
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    NSW SW Slopes
    Its no good going to a LR dealer as their equipment does not have the ability to edit individual CCF settings - a Faultmate or IID tool is needed. Whilst I didn't try changing D4 headlight specs because I didn't have a need, I changed various other CCF settings with my Faultmate that a LR dealer could not change, such as disabling the steering column lock and changing the various speedo and fuel consumption correction factors.
