Results 1 to 10 of 27
Thread: 1HD tojo crap performance
    Apr 2012
    Orange, NSW
    Howdy.
    Let me stop you before you start, no 'it's a Toyota they're all crap' comments please
    We have a pair of 1HD tojo utes at work, in addition to our 3 1VD V8s.
    One of the 1HDs is fine, pulls like a train, loaded or unloaded.
    The other is fine empty but once you put a load on it it's a slug. I towed 50 bales of straw in a box trailer today and I was down to third gear up minor hills trying to maintain 70kmh and failing, the other 1HD charges up hills in 5th gear with trailers full of drill core and scrap metal, much heavier than today's load. Even unloaded with just the trailer it was noticeably bad.
    Vehicle is serviced every 5-8k kms, well maintained, and has at some point had a top end rebuild. 276k on the odo.
    Suggestions please
    Muppet
    Sent from my HTC One using AULRO mobile app
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    South Sydney
    Should be replaced with a 300tdi auto.
    The be-all and end-all of tow vehicles.
    Free Again Thanks Dan
    Quote Originally Posted by MR LR View Post
    Mmmm i smell at rat in that hole
    Partially blocked exhaust?
    Needs a high speed highway run?
    Jun 2014
    Dubbo
    Im just going to spit out some ideas without knowing what you've already checked..
    Air filter, air hose (collapsing), fuel filter, fuel strainer in tank, compression, dragging handbrake/footbrakes, injector pump inlet strainer, exhaust blockage.
    Kingston, Tassie, OZ.
    Egr valve stuck open is my best guess. They can also go into limp mode with overboost due to wastegate actuator pipe splitting. Have you put a boost gauge on it? And how many kms since it had a set of injectors? It is also possible to mistime them has it had a timing belt recently? These are a great engine it should pull well .
    Jc
    Oct 2010
    Adelaide Hills
    Jun 2014
    Dubbo
    Ahh of course, EGR valve. I was thinking of a 1hz before for some reason.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by rangieman View Post
    Some one let the work experience kid at the computer again.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    cafe latte Guest
    Quote Originally Posted by Beery View Post
    Fore sure check the strainer it is in the fuel in or out pipe cant remember which, remove the banjo and you will find it. I have seen them full of crud, car works, but sllowww.
    Chris
