Thread: Engine bay wires rubbed through See pic
    Oct 2012
    Adelaide
    Question Engine bay wires rubbed through See pic
    Hey all
    Was doing my monthly oil and water check on my 01 TD5.
    Ive noticed the 2 wires coming from a connecter plug under my oil filter and going over the transmission have rubbed though and are no longer connected to anything.(see photo)
    Does anyone know what these cables do, as the car runs no worries.
    im guessing they just illuminate the dash for low oil?
    what do you legends think?
    Apr 2010
    South Melbourne
    Yep, correct -.low oil pressure warning. Just trace back to RH side of engine and replace worn wire sections. It's part of the engine loom harness.
    Oct 2010
    Caloundra
    BTW, as far as I know, only one of these wires actually connects into the loom. The other just sort of hangs out there.
    Td5 Oil pressure switch wiring
    Oct 2012
    Adelaide
    Easy, one wire is still connected the other which i assume rubbed though is the one which doesn't do anything at all! thank you everyone for you help! ill put some new sleving over the cables later today! legends!
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by Warrzone View Post
    I wouldn't assume it does nothing unless you are certain your low oil pressure light comes on when you do an oil change.
