Thread: RRS 20x9.5 wheels on D4
    Jun 2016
    Carnegie, VIC
    I'm looking at an SDV6 SE at an independent used car dealer. The vehicle presents well, and has been listed as having the 20" black pack, but upon closer inspection I noticed the wheels appear to be off a range rover, and are shod with 275/45R20 Coopers. I suspect these are not the standard wheels for the factory 20" pack. Also, the spare underneath is a standard 19".
    Is there any problem running wheels of this size (mechanically, legally, insurance etc). Are there any advantages of this size over the stock 19's/20's?
    This concern has potentially put me off pursuing the vehicle at this stage, as I wonder what else is lurking under there I haven't seen...
    Williams West Aust
    Some D4s do have 20"rims.
    Check from the part numbers on the rim,I believe the RRS rims dont have the correct weight rating for the D4.
    In tyre selection you are looked after better with 20" rims,one of the biggest issues us D4 owners have is the 19" rim and lack of bigger tyres than standard.We resort to a specially made 18" rim,made by Compomotive Wheels UK,and marketed by Green Oval Experience.(Gordon,GGHaggis on here)
    There is a spreadsheet on the Green Oval Experience website that lists tyre/wheel combinations that fit the D4.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jun 2016
    Carnegie, VIC
    Thanks Andrew,
    I would be planning to order a set of Compomotive 18's to fit for more serious trips, and have checked through the tyre size spreadsheet which indicates the 275/45R20 tyres fitted should be ok, but I assume that's with the standard width & offset of the D4 20" wheels (which I believe are 8" wide). These Range Rover wheels (the centre caps say Range Rover) are 9.5" wide, and presumably a different offset, so I was worried there could be clearance issues. I guess I should take it for a test drive and check for rubbing at full steering lock.
    My other concern is the 19" spare. My understanding is that legally the tyres on each axle should be the same, but my current car came with a skinny space saver emergency spare wheel, so I imagine there are exceptions to this rule. I know that running different diameter tyres can send the ECU into panic mode, but going by the numbers in the spreadsheet the 20's should be approx 760mm diameter, while the stock 19" is 763mm so it would probably still get me home when required.
    Feb 2009
    Yeah offset shouldn't be a problem, nor the 19" spare (that's the standard scenario with the 20" wheel option) and 275/45/20 is, as you say, near as dammit in size to the 255/55/19.
    BUT (and I might beat Tombie to the punch here) as LandyAndy says, the RRS wheels are load rated at 860kg whereas Discovery wheels are load rated at 930 kg, meaning RRS wheels aren't legal on a Disco.
    Having unwittingly bought a car with Chinese knock-offs, just peer inside if you can and see if they're even genuine Italian made Land Rover product.
    Either way, a/ the dealer surely can't sell you an unroadworthy car, and b/ if you like 20s just not those ones, you'll pick up a set second hand this evening if you want them.
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Oct 2011
    Sunshine Coast
    I have genuine LR Stormer wheels on my RRS they are load rated at 920kgs.
    Got them after LR dealer originally supplied car with aftermarket Stormer rims, that had a 660kg load rating. They then found another set of aftermarket ones that were rated at 820kg. But, I insisted on genuine and got them. So take care, get one wheel removed and check what is load rating cast into it. Same looking wheels with three diffferent load rating. And no way to tell without removing wheel.
    Feb 2009
    Quote Originally Posted by Meccles View Post
    920 kg, there you go. That's the highest rating I've heard.
    I'm interested - was that a new or second hand car, and from a LR dealer? I'm still at a loss as to how my car was delivered and only ever serviced by a LR dealer before I bought it, yet it has imitation rims. At least the load rating is equivalent.
    Jun 2016
    Carnegie, VIC
    Thanks for all the replies, it sounds like I was right to be cautious - I had planned to take these findings in to the dealer and negotiate further, but the vehicle had just been sold (presumably with a roadworthy certificate from the dealer's workshop...).
    Jan 2013
    Ashgrove Brisbane
    Quote Originally Posted by Stuart02 View Post
    My D4 (2012 HSE) came with 5 20" rims. From what I've seen the D4's that came with optioned 20" wheels get 5 but the RRS ones only get 4. Supports your theory that it came off a RRS. Bit weird doing it that way, but that's our beloved Land Rover I guess.
    Andrew
    Sep 2013
    Nope mine came from factory with only 4 20's & 1x19
    Oct 2011
    Sunshine Coast
    Quote Originally Posted by Victim View Post
    Mine came from dealer with RWC but in fact it had illegal rims on it. Hence I had no real issue getting them changed. But, if I hadn't had a flat, and pulled a wheel off and seen load rating, I would have been none the wiser. So any second hand car even with RWC I highly recommend checking rims even if they look genuine.
