Results 1 to 10 of 26
Thread: Series 1 with holden engine
    Mar 2007
    Tarneit VIC
    Thinking to buy this a series 1 with holden engine. Body I think look straight and going to inpect the chassis tomorrow.
    From thw photo the seller sent me there are some rust holes under the windscreen. The engine seems seized.
    My question is
    1. How hard is it to fix those rust holes shown on the picture or do I need to get a replcement bulkhead.
    2. Do you think is a bad idea to get series with holden engine? Do you think the chassis had been cut to fit the engine? Or they usually used a adaptor kit?
    3. Looking at the photos how much do I need to spend?
    Thanks. Gus.
    australia
    Quote Originally Posted by dearot View Post
    My question is
    Thanks. Gus.
    if you can weld its ok if not it can be a can of worms if the engines seized go back to original chassi no is also a help regards jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by russellrovers View Post
    What do you mean by go back to original chassis no?
    sheerluck Guest
    There was a comma missing, as in if the Holden engine is seized, then go back to an original engine. But also, posting a chassis number will help identify the vehicle.
    Repairing that bulkhead will need an expert welder, but should be possible - although if you can find a good one, it will be a lot easier, and cheaper as well if you are paying a good welder!
    I would tend to fit an original 2l engine if you can find one, or failing that probably a 2.25, as these are readily available, even if you need to overhaul it.
    The chassis is likely to have been modified, and the radiator support as well, but both of these are relatively easy to rebuild or replace in the second case.
    The conversion may have been done using a commercial kit, or a one-off. You need to be aware that some of the commercial adapter plates were not accurately enough made, and result in gearbox damage, so be prepared for gearbox repairs.
    Mar 2007
    Tarneit VIC
    The conversion may have been done using a commercial kit, or a one-off. You need to be aware that some of the commercial adapter plates were not accurately enough made, and result in gearbox damage, so be prepared for gearbox repairs. John
    How can I tell whether it is using a commercial kit or a one off?
    Sorry have to ask to make sure I know what to look for as I never have series nor see conversion kit before.
    Jan 2013
    Molesworth,Tasmania
    I think you can do better than this. I'd keep looking. There,s a nice looking series 3 up north , registered original engine - you could drive it home.
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by Dark61 View Post
    I think you can do better than this. I'd keep looking. There,s a nice looking series 3 up north , registered original engine - you could drive it home. Cheers, D
    I know which one you are talking about. Spoke to him on friday. Got distracted when I saw this series 1
    You can't at this stage! There were several commercial conversion kits, varying from backyard to what we would regard as 'factory' today, and some of the home grown ones were just as good as the best. And then, apart from the bits fitted, there was how well the work was done - even if the best parts were used, the conversion may have been done by an amateur short of time and the result only intended as a farm hack.
    Most of these conversions were done because fitting a Holden engine (readily available and cheap since Holdens usually rusted out long before the engine was worn out) was far cheaper than overhauling the Rover engine, even taking into account conversion costs, and gave a boost in performance as a bonus.
    Mar 2007
    Tarneit VIC
    I would like to make it as original as possible being a series 1. But my main objective if I gonahead is to make it run, get a club permit then slowly bring it back to the original. Otherwise I will be in deep S**** and I can guarantee no more $$$ from the bosss for landy.
    Would be above can be achieved easily knowing that will be cheap repalcement holden engine available?
    To rebuilt or replaced as mentioned what would need to be done? Any project reference on the net that I can have a look or anyone in the forum have done it before?
