Results 1 to 10 of 17
Thread: URGENT - D2a HSE, right front wheel stuck up in wheel arch
    Wantirna South, Vic
    Michael2 asked me to post for him, as he's under the pump.
    He has a 2004 D2a HSE with ACE (obviously). The right front wheel appears to be stuck up in the wheel arch, even when jacking the chassis off the ground. The left rear airbag is fully inflated also, likely to try and keep it on the ground. He's tried to reset the ACE system with a Hawkeye without success, driven it around, LR rebooted etc.
    Has anyone seen this before, and if so, any fix available please?
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    Pennant Hills, Sydney
    Have you tried pulling the ace fuse but in saying that with motor off key on solenoid should be in nuetral position.
    My only suggestion would be to loosen the two fittings to release oil pressure but be bloody careful of sudden movement of vehicle and of course oil under pressure if that is the cause and before any of this is done and might be a stupid question but is the suspension coil spring ok??
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    I've undone the connecting rod for the ACE, removed the tyre, jacked the body and axle independently of each other.
    It's not an ACE issue, it's as if the spring has broken, but it hasn't. Just suddenly it can't support the weight of the front corner. But couple that with the Rear LH airbag being up, the RH air bad is not leaking, but sitting in standard position.
    Kingston, Tassie, OZ.
    Have seen the spring perch torn clean off the rhf chassis rail of a d2a before... the whole lot collapsed. Apparently was a manufacturing / welding flaw. Any chance of pics?
    Jc
    ok, just figured out the larger pic.
    Jan 2013
    WA
    release the air out of the left rear air bag see if the front evens out, might be an sls problem
    Cheers tt
    D2 2004 TD5 Classic
    Apr 2012
    Orange, NSW
    Collapsed shock?
    Edit
    CJC said it better below!
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Bunbury, WA
    Quote Originally Posted by Disco Muppet View Post
    Collapsed shock?
    More like a seized shock (damper), ie locked solid and won't let the spring come back down?
    Ferntree Gully, Vic
    Jc
    Hi Justin,
    Have you seen a few of these happen? I recently saw this on a friend's D2a and didn't know what had caused it. I have pics of it as well. Is it a matter of just getting it repaired properly? uploadfromtaptalk1470924657456.jpg
    Quote Originally Posted by SPROVER View Post
    Hi Justin,
    Yes just a proper repair from a bodyworks or someone experienced in chassis repairs. The one i saw has since done 250k and even spent a few years in the kimberley on those roads without a reoccurence.
    Jc
