Tow bar receiver. Is it on the car? Otherwise you might want to chase it up...
Sent from my SM-G900I using AULRO mobile app
 Member
						Member
						Hi All, new to owning a D4 and have found that i seem to be missing something from the rear left compartment in the luggage space. There is a foam mount and strap that holds something in place but not sure what it should be? I see on the right hand side there is the jack. Any help or pics appreciated.
 Wizard
						Subscriber
						Wizard
						SubscriberTow bar receiver. Is it on the car? Otherwise you might want to chase it up...
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
It's where the removable tow hitch goes when you're not using it.
This bit ................pc screenshot
Cheers .........
BMKAL
 Member
						Member
						Ah! thanks guys, makes sense and also makes sense why it's empty!
 Master
						Subscriber
						Master
						SubscriberGood luck putting it away if you ever need to! It's a tight fit and a bit like a Rubik's Cube - out of many possible permutations only 1 works.
D4 MY16 SDV6 HSEe-diff, IID, LLAMS, ARB Summit bar & Intensities & twin compressor, Traxide, GOE sliders & guards,
TowPro Elite, Mitch Hitch, Rhino platform, Drifta drawers, GME UHF, ProSpeed rear ladder
Never been able to get mine back in the hole.
Lives in the garage with the associated hitch when not in use.
Have purchased a Mitch Hitch so OEM will be redundant -> eBay I suppose.
Ron
2013 D4 SDV6 SE
 Master
						Master
						Yep... whoever designed it should be shot... all that space and somewhere to put just half a towbar! The other is supposed to rattle around in the back somewhere. I did find a neatish cubby hole just between the 2nd and 3rd row
It doesn't look like and item that would be difficult to get back in its hole
No doubting you guys but it just hard to imagine.
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
