Results 1 to 10 of 12
Thread: Alarm system going off and not understood
    May 2012
    Newport Victoria 3015
    The alarm system on my TD L322 which I have had since new has gone of several times over the last few days whilst sitting in my line of view so nobody tampering with the car.
    I can shake the car by jumping on tow bar and the alarm does not go off. I think the tilt sensor needs a few degrees change for it to cause an alarm.
    I have sprayed insect killer to interior in case an insect is setting it off but still it goes off.
    It is happening after car has been driven.
    Once it has gone off in my driveway a couple of times after arriving home it settles down.
    It went off today after driving around 4 km and parking the car in my view.
    I have measured between tyres and guards in case suspension drop was setting off a sensor but no drop can be measured.
    Again I do not think that would cause enough angle change to set it off.
    New front airbags fitted a few months ago.
    Has anyone experienced similar?
    Mar 2007
    Could be FOB battery getting low !
    Check the bonnet switch ! it might need cleaning or adjusting if loose. Disconnect the switch and see how that goes
    Laurie
    May 2012
    Quote Originally Posted by Laurie View Post
    Laurie
    Laurie:Thx for responding.
    I disconnected bonnet switch this morning and so far so good.
    I will report further in a couple of days.
    Have you had personal experience with this issue?
    Mar 2007
    Smile
    I did have a similar problem, but it was on my old D2. Mine was FOB battery low and on another occasion I had the bonnet lock off centre, but that alarmed almost immediately.
    Laurie
    Manly QLD
    The alarm on my L322 went off several times over 2 nights (and I assume while I was at work during the day). Ended up moving it and leaving it unlocked. Over the next few days a very large huntsman was spotted inside. He was removed, not gone off since.
    DiscoMick Guest
    I'm not familiar with the L322 alarm, so this might be wrong, but we did have to replace the switch under the bonnet for the alarm on our Defender because a faulty switch was affecting the alarm and it didn't always work properly when the bonnet was closed.
    DiscoMick Guest
    Quote Originally Posted by harlie View Post
    That story reminded me of when a huntsman took up residence in the wife's Mazda. She was driving along one day and he appeared on the dashboard. She slammed on the brakes, parked, grabbed a magazine and beat the poor thing to a pulp on the dashboard. Then she refused to touch it, drove home, and made me clean the mess away.
    May 2012
    Problem licked thanks to Laurie
    I have had the bonnet switch disconnected for a couple of days and alarm no longer goes off. Thanks to all who responded and my special thanks to Laurie
    Kingston, Tassie, OZ.
    Yup just had the same issue. And happens in d3 and d4 also.
    Jc
    Mar 2007
    Uteman thanks for the compliments, glad to help. I like almost everyone here has saved money, time and frustration from advise and help from members on this forum. This is why every L322 owner should be a member here.
    Laurie
