Results 1 to 10 of 21
Thread: Strange engine noise
    danm14 Guest
    I have a strange ticking/rattling sound coming from my sdv6 d4.
    Seems louder while idling and does it cold and warmed up.
    Doesnt get louder when driving and I cant here the sound from inside the cabin.
    I have no loss of power or any ecu codes showing up.
    Seems louder from the passenger side of the engine.
    I will post some links to youtube where I habe a couple of videos.
    Weird ticking sound - YouTube
    Weird ticking sound 2 - YouTube
    Mar 2016
    Have a look at the serpentine belt. In there you’ll see an idler up the top on the belt run. See if that’s moving about a lot. It sounds like it could be a faulty idler allowing the belt to flap. It’s not uncommon. How long has it been doing it? I’m hoping it’s that simple.
    2007 Audi RS4 (B7)
    May 2016
    Londonderry, NSW
    Quote Originally Posted by danm14 View Post
    Sounds like tappets need adjusting
    danm14 Guest
    Quote Originally Posted by DiscoJeffster View Post
    I just noticed it the other day...
    Hopefully it is that simple!!!
    Jul 2010
    Hunter Valley NSW
    Jul 2013
    Agree with the general comments so far, remove the engine cover and have a look at the serpertine belt tensioner (bottom drivers side down near the alternator) as it may have failed. Its the actual tensioner that fails and not so much the idler itself - the tensioner falls apart and the belt dosent run on the pulleys correctly - especially the alternator pulley.
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    danm14 Guest
    Thanks for the reply guys.
    I had another look, and I dont belive its coming from the pulley or belt area.
    Still sounds like the right side of the motor.
    Also noticed an oil leak around there and the filter housing.
    I recorded another video with the cover off and emphasizing the side which the sound is coming from.
    Ticking sound part3 - YouTube
    Mar 2016
    I'd seek professional advice. It's very hard to pinpoint on a video recording. There is an element of sounding like an open exhaust sound to it as well. I have heard of the rear exhaust pipe that joins the left and right sides together failing. It's buried behind near the firewall. Other than that, sorry, dunno. Keep looking, feeling for leaks etc, if it's not the belt.
    2007 Audi RS4 (B7)
    Oct 2013
    Old Toongabbie, Sydney NSW
    This may or may not help but I remember my old man using a length of dowel held against the engine to locate noises. He would put his thumb over the end and press his ear to the thumb. Apparently the sound would travel up the dowel and he could hear if something was wrong. May help you locate the location better.
    Martin
    Mar 2016
    Any luck finding the source as yet?
    2007 Audi RS4 (B7)
