Results 1 to 10 of 14
Thread: ABS Codes checking / clearing in Adelaide
    Mar 2018
    Drouin / everywhere around the country
    Hi @ all!
    Got the advice to ask here again.
    After some time with the 3 Amigos, the Error became permament. Means that the ABS-light stays on after ignition check and then the HDC and TC lights come in addition. Now I made the „Option B“ and checked all 4 ABS-Sensors (1000Ohm).
    Guess I have to clear the codes now (maybe hit the magic 256?!).
    I‘m in Adelaide in the next few days and looking for a workshop recommendation or (preferred) a member to check/clear the fault codes.
    Tried two general workshops on the way but noone had the right interface to access the ABS.
    Thanks!
    Jan
    Dec 2016
    New Lambton, NSW
    Try here
    Members with Diagnostic Equipment map (updated 1/2015)
    May 2015
    Williamstown, Victoria
    The lights stay on if the error occurs 20 times. I rest mine with a Nanocom.
    Build date 11th Oct 2003
    LROCV #1410
    Sep 2012
    Adelaide Hills
    down south at TRS, they can isolate the issue, and they have a kit that can sort it. from memroy its a speed sensor or abs modual thats bad.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Dec 2008
    Yatala Vale, Adelaide, SA
    send me a PM to see if I can help, I am based in the North but am in the south quite a lot.
    Mar 2018
    Maybe interesting for others: PCB charges 100$ to plug the interface in the Disco.
    Thanks to steve_a - we will check it tomorrow.
    Sep 2012
    Adelaide Hills
    just remember, cleaning the codes wont fix the underlying issue. it will return
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Adelaide - Torrens Park
    Quote Originally Posted by Mr.Ignacio View Post
    I wouldn't charge that much...
    Mar 2018
    Thanks again to steve_a for all the help and hospitality!! We checked / cleared the codes and the amigos were gone. One fault left after testdrivd: Brake light relay short to internal. HDC light came on one time yesterday. And today after a hill descent with break squeal, the amigos are back and permanent. So I think the „break light relay short to internal“ fault came up too often.
    Can‘t find anything about this relay, except that it should be the HDC relay as well? Where is this relay and what can I do?
    Jul 2014
    west of Transylvania
    It's a built in microrelay part of the interior fusebox soldered into the PCB, not simply replaceable nor availabte as spare, all you can do is to replace the fusebox
