 Originally Posted by
PAUL200
				Hey folks,
I'm planning to fit an electronic brake controller to my 130.
I am trying to find a grey connector that is apparently fitted near to to fuse box (under steering wheel) for the connection? Does anybody know whether this connector exists in my 2015 version of the 130? There is also a black box above the brake pedal with two switches - is this related to the brake controller?
I have managed to install the tow bar and connected the socket to the loom under the right rear wheel arch no problems - all tested and done no issues.
Is it the 'SERVICE BRAKE' wire that controls the electronic brakes on a 7-pin connector?
Any advice greatly appreciated as always
 Most of the trailer wiring is available in the plug on the factory loom but brake connection isn’t. You will need to run a sense wire from the brake light to the controller and a sufficiently thick brake wire from the controller to the plug at the back of the vehicle.
You should also consider the gauge of the power supply wire to the controller
Yes, the service brake is where the output from the controller goes to. The wire is usually blue in aus.
I’d send some pics but 300km from the Defer
Tote
2014 Chile Red  L494 RRS Autobiography Supercharged
