Results 1 to 10 of 40
Thread: Kuhmo MT51 mud terrain tyres
    Jan 2011
    Gippsland
    Is anyone running Kuhmo MT51 tyres on their D2 - i’m seriously considering a set of 235/85/16s to go onto stock steel rims. I have an LRA 40mm spring lift and with the rims being standard offset I’m not expecting rubbing issues..
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Feb 2011
    Hobart, Tasmania, Australia
    Quote Originally Posted by onebob View Post
    On standard offset wheels, you will likely have rubbing on full turns unless your extend the stoppers out.
    Jan 2011
    Gippsland
    Quote Originally Posted by twr7cx View Post
    Thanks - I will get under the front and see what length stops i have - hopefully i have the long 29mm stops fitted from factory...
    LROCV member #131
    Oct 2012
    Wollongong
    Yeah I’m running those tyres but in a different size.
    The name is misleading, they’re much more an A/T than M/T.
    Seem to get noisier as they wear.
    LT construction and ride is pretty harsh.
    Aug 2017
    Rover
    Ive just put a set of Kumho AT51’s on my Defender. Only done 1000km, but pretty happy with them. Great in the wet today, really grippy on gravel. Slight road hum on fast corners, otherwise quiet. I like them so far. Good price too.
    Jan 2015
    Brisbane, QLD
    I’m running 245/70/16 on my D2. Have put 5000km on them. Very happy. A good inbetween AT & MT tyre. There is a slight noise increase in town- but you have to listen out for it. Get noisy at 100km, but not nearly as bad as a full MT. Really happy in the wet too. Have only been off road a few times with them, but haven’t had any dramas. Price is pretty reasonable. Would recommend.
    Cheers, Josh
    Feb 2011
    If not they're not then they're a standard thread type, so you can use a normal bolt, preferably a cap screw (alan key head) and a nut on the thread to lock it off, that way you can custom length them to the shortest possible with no full lock rub and maximising steering.
    Quote Originally Posted by ballbag View Post
    Are you sure that you have the MT51 then and not the AT51 - one is an all-terain and one is a mud-terrain with the same two digit code which can confuse.
    ROAD VENTURE MT51
    ROAD VENTURE AT51
    Oct 2012
    Wollongong
    Yep, I’m sureKuhmo MT51 mud terrain tyres
    Jan 2011
    Gippsland
    ROAD VENTURE MT51
    ROAD VENTURE AT51
    Thanks for the useful advice.... I did check and I’ve got the 23mm steering lock stop bolts fitted .
    LROCV member #131
    Jul 2011
    Yarrawonga, Vic
    Thats funny, Ive got MT51 225/75R16 on my Lightweight and they are looking different again
