Thread: AFT Leak
    Feb 2015
    Vic
    AFT Leak
    Update. Was a loose connection. Will keep an eye on it after I top up the ATF.
    Original post follows.
    This is a 10 minute puddle. I just pulled it up to change the steering dampener. It us running from what I assume is an oil cooler line.
    Any ideas?
    St Helena,Melbourne
    4.28 MB
    Yep, trans fluid cooler, o-rings at the box end and quicjk connects at the other end i believe - a common failure.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2011
    Hobart, Tasmania, Australia
    Might have upset the quick connect (which personally I've found to be anything but quick to take off or put on - might be the years of dirt and grot built up disrupting their smooth movement). If your lucky you can just reconnect it to the automatic transmission cooler unit.
    Feb 2015
    Vic
    Fixed. Updated the OP.
    Feb 2011
    Strange that the threaded fitting had worked it's way loose. Glad it was a free repair then though but. Make your you use good flange nut spanners or crows feet on them to avoid damaging the hex.
    Feb 2015
    Vic
    Quote Originally Posted by twr7cx View Post
    More tools to purchase
    Nov 2015
    Merbein
    35.44 MB
    Ditto on the O rings getting tired and loosing tension.
    PeterN
    70' 164 Manual Volvo 227,000miles play car. "Sven"
    2001 BMW R1150RT bike, 118,000Km "Bruce"
    2000 D2 TD5 Auto 329,500Km and climbing. "Leaky" (VK3JUG)
    2024 Dualcab Hilux work truck, 12,000Km.
