Results 1 to 10 of 15
Thread: Getting a County heater to work
    Has anyone had any luck in getting the County heater to put heat into the cabin when it is cold outside?
    It's as though the heater doesn't flow enough water or the core is too small to transfer heat.
    I get plenty of heat when it is hot, very little when it is cold.
    Ron
    Camp Hill Queensland
    Yes Ron, mine works.
    Was in the high country last weekend and it took 20 minutes for it to be noticable because it was -6 outside @ 7am.
    Like the aircon, not the most powerful units but still thankful that they are there.
    I might try removing the vacuum controlled heater valve to see if that allows more water flow.
    Ron
    You can excuse the Poms for not getting the Aircon right, but it makes you wonder when they can't get the heater to work. I was in Tassie last year and it was freezing. The Extreme heater did the job but only just........... 8O 8O
    At least the P38A heating and air con is top notch.
    Ahh, it's French (Valeo), not British (Smiths).
    Ron
    the shire
    big ron
    my county without the o was warm as toast
    it caught fire twice!!!!
    shame it was a 45 degree day
    the big exhaust ran so close to the floor it would turn my boot soles to jelly
    Wheelers Hill, Melbourne
    Ron,
    Did you get it to work?
    Mine is R/S and probably a valve or something. You mentioned that two valves need to open.?
    I've never bothered but we are going on our "big trip" in a couple of months and the family is a bit soft.
    I presume redfenders county had an aftermarket exhaust. My aftermarket exhaust had a tiny pinhole from new and had a similar problem, the wife broke out in a sweat, but luckily nothing caught fire.
    SYDNEY -in the shire.....
    <span style="color:#3333FF">have you guys tried flushing out the heater matrix to make sure its not full of years of rust and crud....
    and possibly mud....?
    this may be restricting the coolant flow through it......and hence reducing its efficiency.......</span>
    Two Rocks WA
    Ron I thought u had sold the county?
    or am I imagining again?
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Allestree , its all good.
    I traveld from a top end wet to a Tassie winter and could not get any real warmth out of the heater even after flushing the heater core and renewing the control valve,(stage 1 V8) Locals gave some bumff about radiator being to big ,coolant being used , but I dident stay for another sleet season and the heater worked fine back in WA.
    '99 Tdi 300 130 Twin Cab
    When I'm here I want to be out there.
