Results 1 to 10 of 12
Thread: Workshop compressor capacitor
    Wheelers Hill, Melbourne
    My compressor needs a "hand spin" to get going. Apparently, there are start & run capacitors & I need to replace the start one.
    Which one would it be? Google is no help.
    Sep 2010
    The Hills.
    152.79 MB
    Pretty sure it's the bottom one with the higher Microfarad number, but at around $50 each ( last time I did one ) why not do both? I got it from a motor place in the Gully, but I suppose Dandy would be closer for you.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2018
    Perth (near Malaga)
    ^^^ What he said. And if the start cap is duff, the run probably isn't far behind.
    Jan 2010
    Perth S/W
    Very easy to test them for anyone with the right meter , literally a 1 min job .
    Could also be the centrifugal switch or the start winding .
    Quite often when they go they split & smell bad .
    Nov 2014
    G'day All,
    "Rockby Electronic Components" Melbourne has motor start/ run capacitors for a few dollars. This is the link to the page:
    Search Results Page
    They do mail order as well and if your value not listed give them a call to check stock or where to buy at good price.
    Both Capacitors can be purchased from Wiltronics Melbourne:
    Motor Start Capacitors | Wiltronics
    Chris
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by dero View Post
    Or catch fire and start spewing smoke into your evap cooler which then fills the house , that was fun - not.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2010
    The Hills.
    152.79 MB
    Wow. Another reason for me to like that mine is 3 phase.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Aug 2010
    Sunbury, VIC
    There was a house burned to the ground last week in Melbourne somewhere where the fire started in the evap cooler on the roof.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Homestar View Post
    Not the first time either.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Aug 2010
    Sunbury, VIC
    I didn’t think it had been hot enough yet for AC this year in Melbourne - I installed new AC in the house 2 years ago along with really good insulation - I could count on one hand how often we’ve used it since, but I am glad it’s there for when it’s needed.
    I think Saturday may be a day it gets a run based on the current forecast.
