Results 1 to 10 of 14
Thread: HF antenna folding mount
    Jun 2008
    Drouin East, Vic
    I've got rid of the big box canopy thing on the back of the 130 and in the process have lost my HF antenna mounting point. I've installed a tray, acquired a Trayon camper and the need to silde the Trayon on & off precludes a rigid mount at the back of the vehicle, wanting to be able to see the road kinda precludes a rigid mount at the front (Codan 9350 antenna). I'm left with the option of a folding mount on the bullbar so the antenna can be laid down for travel. Brainstorming ideas in the shed tonight but rather than re-invent the wheel, I'm wondering what others have done for a folding antenna bracket.
    Sep 2014
    Hunter Valley NSW Australia
    You can actually buy one designed for just that purpose, there are also smaller ones for HF and phone aerials.Aerpro Bullbar Folding Antenna mount
    The link is for a UHF one but there are heavier duty ones for HF, I've got one and had it for about 6 or 7 years now.
    If you are handy it wouldn't be hard to make one from a couple of bits of square tube.
    One addition I made was to make a padded saddle for the top of the antenna to sit in when folded down as it reduces the weight and leverage on the actual mount. I have a Barrett autotune antenna.
    Jun 2008
    Drouin East, Vic
    Thanks for the link, that looks like not a bad design. I'll certainly be putting a cradle on the other side of the bullbar to carry the top of the antenna base, which means that the folding mount only needs to latch in the vertical position.
    Sep 2010
    Moe, Victoria
    This is exactly the solution I was looking for your help with years ago Peter, as trade for the multi-tap! Never got it organised. Perhaps its time! Design once, implement twice?
    I have a one of these brackets in hand, and my broad thinking was to have it mounted on the bullbar, with a cradle on the wing that would would be made with an alloy sheet base plate that replaces the existing wing blanking plate. I was think the cradle would have a bungee to hold the antenna horizontally - but I've never really done any thinking about the specific design.
    UHF Phone Antenna Bracket – EMIC Industries
    Jun 2008
    Drouin East, Vic
    In my brainstorming I've been looking at folding it across the bullbar, I'll have a look at the possibility of folding it back onto the wing top. Bit worried about where the cables will end up though.
    Edit: Had a look at the possibility of folding it backwards to rest on the top of the guard, or wing. It might depend upon how high the top of your bullbar is, but with my standard ARB bar, this would require the base to be quite high above the bar to get the antenna to lay down horizontally. Also it would end up with the bracket protruding high above the bar when folded, which I think would be a liability. Folding it across the top of the bar, it would lay down in front of the bonnet and a cradle could be mounted to the bullbar; there are two antenna brackets existing on the top of the bullbar, my plan is to add a heavier mounting point to the bullbar above the LH headlight, the UHF antenna is mounted to the existing LH bracket, the autotune will lay down behind the UHF antenna and be cradled at the RH bracket.
    Sep 2014
    If you are going to make a saddle for the antenna to sit in when folded down then the saddle has to be on the same part of the vehicle eg: if the antenna is mounted on the bull bar than the antenna needs to fold sideways along the top of the bullbar.
    You can't have the antenna mounted on the bullbar and tha cradle on the mudguard as they move independantly when the vehicle is moving. Destruction of the antenna would result.
    The brackets are designed to hold the antenna at either 45 dgrees or horizontal when folded but I found that even with a heavy duty HF designed mount that the weight of the autotune antenna quickly flogged the holes that the hinge and stop located in allowing the antenna to flop around which led to me making a saddle for the top of the antenna to sit in when folded.
    The saddle needs to be well padded and also have a velcros strap or similar to keep the antenna in place in rough terrain which these days includes most bitumen roads!
    Mar 2015
    Horsham Victoria
    Or consider a Codan 3040
    Jun 2008
    Drouin East, Vic
    I've strongly considered a 3040, I'm sure it would be a solution for many people but I don't think it would help me, the only place I could mount it would be on the top of the bullbar so I don't think I'd be any better off, looking at a shoebox rather than a telephone pole. If I had a single-cab ute, a 3040 would be able to be mounted on the headboard in front of the camper, but with the dual-cab the camper extends over the rear of the cab. Mounting behind the camper would have no advantage over the 9350.
    Jun 2008
    Drouin East, Vic
    I just ordered the 'Don't bend em etc' folding bracket; I'll have a fiddle with it when it gets here and see how best to cradle the top of the antenna.
    Jun 2008
    Drouin East, Vic
    I've mounted the Codan antenna to the 'Don't bend em fold em' antenna bracket. This is a nice bit of kit, well made and it arrived in a couple of days after ordering. I don't think it would be robust enough that i would travel with the big Codan antenna mounted solely to this bracket though, it's clearly designed with smaller UHF type antennas in mind.
    i had to cut the long mounting bolt of the 9350 down quite a lot shorter to enable it to mount to the bracket. I was reluctant to do this- felt like I was going to get in trouble somehow! I guess that's the feeling one has when messing with things you don't fully understand. No more padlock hole- but every villain has a cordless angle grinder these days anyway.
    I'm going to have to make some kind of guard for this; I'd hate to see what it would do to a pedestrian. I'm happy with the fact that the cable connections end up behind the post of the bullbar when travelling.
    Made a bracket to carry the top end of the antenna on the other side of the bullbar.
    bracket RH view.jpgbracket 1.jpgantenna folded front view.jpgantenna folded RH view.jpg
    I'll put some adhesive-backed foam padding in the cradle after it gets a coat of paint. One thing I would change if doing it again; the slotted hole for the bungee strap should be at the front, it's quite fiddly to get to it especially to release it, being close to the bonnet. That's the nature of 'design as you go' fabrication though, what you end up with is always a prototype. It will do the job.
