Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Computer Crashing
    MickS Guest
    Computer Crashing
    Hey guys,
    My PC has, for the last day or so, been just shutting down and re-booting by itself. Usually when we're in the middle of something (internet/email/word).
    When it restarts, there is usually a message saying "a serious error has occurred" and logs the error.
    All my virus software is up to date, I've done a full scan and it comes up OK.
    When it reboots, it says "system health OK" and all the other normal start-up stuff.
    Any thoughts would be appreciated.
    Mick
    Oct 2003
    Montrose, Vic.
    Hi Mick,
    I am assuming you are running windows XP.... if not let us know and we may have other ideas.
    First right click on your my computer icon, select Properties.
    on the box that opens go to the advanced tab and click the settings button near the bottom under startup and recovery.
    In the middle under System Failure, there is a tick box marked Automatic restart.
    Take the tick out of this box and click ok until the boxes close.
    Often when there is a major issue, Windows will "bluescreen" - this screen has error info on it.... but by default windows is set to auto reboot.
    With many machines this happens so fast most users never see the blue screen.
    What I've suggested above will NOT stop the issue - but if you now get a blue screen - you will be able to post the error info and someone should be able to help...
    Cheers Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    MickS Guest
    Mark
    Thanks mate...you're a genius. Just did all that you suggested and shall wait to see what happens.
    Mick
    Oct 2003
    Montrose, Vic.
    Mick,
    If and when it blue screens... a lot of what is there will look like gobble-de-gook..
    probably like this:
    Write down and post the bit above that starts *** stop:
    and the file name - above it is the ati2dvag.dll
    This will give us a hint what is happening.
    If it just reboots still - it might be a hardware issue rather than software
    Time will tell.
    Cheers Mark
    Mark
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    what occurred just prior to this behaviour occuring? new usb device? or new software installed ?
    what is the specs of the system
    how much ram? how many hard drives and cd's etc and how many watts is the power supply rated at?
    if you have a multimeter check the voltage of the power supply.
    the above symptoms are classic signs of low voltage.
    check it at a molex plug with the system going
    red wire and black beside it
    and
    yellow wire and black beside it.
    they should be greater than 12v and 5v
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    I had similar problems with a previous PC of mine. The fan had failed so the processor was overheating and shutting down.
    Ron
    MickS Guest
    Ok guys. I was half through a reply when it crashed again. The blue screen came up and amongst all the gobble dee gook said:
    The problem seems to be caused by the following file
    win32K.sys
    PAGE_FAULT_IN_NONPAGED_AREA
    STOP: 0X00000050, 0XE1CD1000, 0X00000000, 0XBF82CD8E, 0X00000001)
    win32k.sys - address BF82CD8E base at BF800000, date stamp 43446958.
    Inc, it's running windows XP professional 2002 service pack 2, 1.81ghx, 512 mb ram......has 2 cd/dvd drives, just a bog standard desk top PC about three and half yrs old which I'm about to throw into the pool!
    MickS Guest
    Quote Originally Posted by incisor
    Mate it happens anytime. Browsing the internet, checking emails, working in word etc. You hit a key and bang, shut down/restart.
    I haven't added any new hardware or software other than a new mouse last saturday.
    Now, when I'm online, I try to click onto a website and it refuses me access, even my homepage. I have to restart it to get my browser working again.....
    Could be your hard drive going bad. If so, save anything important immediately.
    Do that anyway.
    Simon.
    Oct 2003
    Montrose, Vic.
    Hi Mick,
    Watch other blue screens and see if different files are listed.
    Did the issue start after you installed the new mouse?
    If so... can you change back to the old one and see if anything changes. ( may need to roll back the mouse driver from device manager. - hit the windows key and Pause/Break together > from the box that opens select Hardware tab>device manager button. find the mouse>right click and select properties>select the driver tab>Roll back driver)
    I have not seen a mouse cause this - but that doesn't mean it can't - often these errors are caused by a driver file for some hardware - also I have seen this with faulty Ram. ( don't run out and change your ram just yet though..)
    Is there any possibility anyone has changed any settings in the bios? ( changing memory speeds can cause this too.)
    Try and think when it started happening.... then think about what changed in the day or so before that - new mouse may be it... or installed a program - did an update ( particularly drivers from Microsoft) - changed a bios setting, plugged in any usb device...
    Often if you can work out what changed- that can be the key.
    How confident are you inside a PC?...
    Mark
    Mark
