Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 150
Thread: 130HCPU camper/trailer build.
    Padstow NSW
    this will be an ongoing project as funds come available
    something like this.
    my tub thanks to LVS.
    and the base, ready to be tacked up.
    the base has 14.29m of 50x50x5SHS @ 6.39kg/m thats 91.31kg.
    im going the coil spring route, via a 4 link axle setup.
    im wanting to use trailing arms, bushes, springs, shocks ect off S1disco and defender, just in case
    after the axle and suspension comes finding 3x 16x7boost alloys and mt117 sports to match the 90.
    i have a tanami touring tent, center pole with the extra bit out back, that will be attached to the tub top via a fold out base, stabilizer legs ect. the base will be hinged and able to be opened, when tent packed, via some gas strutts.
    2x 60l water tanks under the floor. batterys and or gas bottles up front in a seperated locker box.
    i want the trailer to be dual use, so i wont be fixing many things inside the tub. most the gear will be packed into plastic tubs and im thinking a drifter type kitchen.
    so when i want to use it as a trailer for a load of dirt ect. i can remove the tent and base and the internal containers.
    thats the plan so far.
    stay tuned
    cheers phil.
    mr_sav Guest
    OK, Now I am really envious.
    My dream, to have such a trailer rig. Maybe I should bite the Bullet and source the rear of a 110. Albeit I would probally remain with Leaf Springs.
    Padstow NSW
    im only going coils and 4 link cos thats just me! i like to be differant
    leafs will be really easy.
    cheers phil
    Padstow NSW
    NO IM NOT! found something esle even easier and alot more robust!
    no shocks springs coils pins bushes etc etc..
    alko IRS axle disc brakes and all.
    cheers phil
    make a second sub frame for it, hing it at the back, that way you can also use it as a tilt frame for when your carrying dirt...
    Im planning on doing this to the one that I was making up ffrom whats left of bug 2.0
    Daisy Hill Queensland
    Quote Originally Posted by discowhite View Post
    cheers phil
    How much and can you get the disc's to become electric activated?
    :TakeABow:LAND ROVER
    Don't Follow Me, I'm in a "Land Rover", You WON'T make it.
    aut viam inveniam aut faciam
    RR5L Guest
    I like the idea of these alko units, what is the axle rated to? As a matter of interest should one of the rubber bushes fail is there a way to lock the swing arm so you can limp home? Are replacement bushes available and easily replaced? Certainly makes for a simple axle assembly.
    Padstow NSW
    if it ever wears out!
    we have this type of IRS setup on thousands of our towable equipment, weights from 300kg up to 3000kg. the abuse that hire equipment cops is a testament to how bullet proof these axles are! most of works compressors are now over 10yrs old and have not been re bushed!
    on the end of the ''swingarm'' inside the main tube is a tortshion(sp) bar thats fixed in the center, that acts as the shock but rhe rubber also has the same dampening effect.
    yes the bushes can be replaced, fairly easily and if it did fail, a big if there, i spose you could jam timber in there.
    but im so confident in these axles i de say that it would never happen!
    this one is rated to 1500kg
    link http://www.alko.com.au/vehicle/axles/irs.html
    havent looked into it yet but i wasnt gonna bother i'll try the hydraulic over ride route first..
    cheers phil
    BigNev Guest
    Alko Axles
    I had an A-van on an Alko axle. I towed it to and from Melbourne inland and back via the coast, Townsville a few times, and Townsville, Darwin, Daly River and further west to Wadeye through creeks and over millions of corrugations, then back to Brisbane area in as straight a line as I could from Mount Isa.
    My only mishap was to wonder how the dust got in, in one little heap only to find my pepper pot had fallen out of its alocated spot and spilt.
    The A-van is now doing service with my son in Townsville and been out to Winton and back that I know of.
    I've never heard of an Alko failure. Have any heard of VW torsion bar suspension failures?
    BigNev.
    Upwey, VIC
    are they expensive ?
