Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Lan
    May 2003
    On The Road
    Lan
    thought I'd give this another go,,
    two XP SP2 PCs
    one, extra clean,(GREENY) nothing but XP.
    the other (BLUEY, we are not big on numbers here,,,)has a, er few extra things on it,,
    greeny has an ASUS A7V333 so no lan chip,, but has a NEW network card installed and after running the wizard tells me there is no incoming connection, also no connection icon in tray.(box is ticked)
    bluey has a gigabyte 7vm400am-rz
    basicaly, its all "on-board"-- LAN is handled by a "VIA vt6103" chip.
    NEW (this morning) network crossover cable.
    during the network (BLUEY) wizard it tells me a cable is unplugged(which tells me I've just wasted my money on a new cable as this is the same message I got last time).
    yes I DO have another network card,, two infact,
    one is identical and the other is an old D-link.
    swapping hasnt helped.
    switching firewalls off makes no difference, [it is interesting that windows now acknowledges other
    firewalls and virus software]
    I'm getting faster at hitting this particular brick wall
    any ideas?
    May 2003
    On The Road
    hmm,,
    could it be??
    one end ethernet,,
    the other not?
    When you plug the cable in you should see lights flashing on the card. If not, you have a problem with the cable or the cards.
    If you do have flashing lights then it's a software issue.
    First thing is look for the lights!
     2005 Defender 110 
    I assume you are setting up a peer-to-peer connection.
    Does your card support automatic sensing so you don't need a cross-over cable?
    Ron
    May 2003
    On The Road
    yep two green lights,,
    now.
    but!
    I put the second lan card into bluey,,
    disabled the on-board lan,
    now I get a second network symbol, but it has "limited connectivity"
    when I ask it to repair itself
    it tells me it cant renew its IP address,,
    Alderley, Qld
    Did you allocate an IP Address on each? Use something like 192.168.1.1 and 192.168.1.2 and see how they go. You also need to have File and Printer Sharing for Microsoft networks. Make sure the network card speeds and duplex settings match.
    Russ
    May 2003
    On The Road
    yup I had to add it in, in device drivers,
    I thought XP auto allocated IP address?
    and then tried a "repair" on the connection,,
    still needs an ip address
    Toowoomba, Queensland
    Quote Originally Posted by Brisruss View Post
    Russ
    I'm not used to doing Perr-to-peer in fancy operating systems. The sure-fire way (but fiddly) is to get into the settings and manually set the addresses to something like the above, and set the subnet mask to 255.255.255.0
    What is probably happening is that the subnet masks on the two computers are not in agreement. E.g. one is defaulting to an address of say 10.0.0.1 and the other to 192.168.1.1 but their masks (which will probably be 255.255.0.0) don't allow them to speak to each other. If you manually set the addresses and the subnet mask yo shold get communication.
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    That could be the problem - they are BOTH allocating the addresses. But more likely the subnet masks and addresses are not in agreement.
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1988 County V8
    REMLR No. 215
    May 2003
    On The Road
    hmm ok,, and where do I find subnetmasks?
