Results 1 to 10 of 13
Thread: price to overhual clutch in D1
    Melbourne, outer South East
    hey all...
    just wondering what's a reasonable ball park price these days for a shop to overhaul a clutch in 300Tdi Disco ?
    .. assuming including replacement of all necessary bits and rear main seal.
    gathering quotes this week.
    wander Guest
    Whayne i would suggest you would be looking at around $1500.00 plus for the job
    Fairfield VIC
    why, whats it doing (or not doing)?
    Ferntree Gully VIC
    around the $1800 mark
    130's rule
    Quote Originally Posted by mns488 View Post
    release bearing on half pedal depression noisy getting worse, rattles from bell housing on start up ( maybe pads on the clutch plate are loose or some issue with fork ), shudder on take off getting worse, rear main engine seal leaking, Mech reckons by feel of it clutch fork may be wearing on pivot point.. ( i think that's what he said.),
    ..not slipping as far as I can tell.
    nothing a show stopper (yet) but don't want it to pack up on me in the bush.
    bit disappointing as car's only done 120,000km ..i was hoping to get more out of a clutch.
    Ray what you said is about what i've been quoted ....so all's good.
    NSW far north coast
    around the $1500 mark in these parts.
    Interestingly, about the same for TLC's and Patrols.
    Quote Originally Posted by waynep View Post
    Not uncommon on some models but I'm not sure which. the ball can punch through the fork. Put in a new fork, too.
    I've seen some mechanics weld a plate across the back of the fork so that when it wears out, the ball doesn't punch right through.
    wander Guest
    Whayne also have pivot checked when done i was lucky when they had to redo rear main found aluminium braket had cracked.The pivot pin would have dropped out and no clutch can supply prices of all parts if you req.
    I had the clutch fork on the Disco break last August & the mechanic suggested that ever though the clutch was only half worn (180,000km), it would be worth replacing while the gearbox was out.
    All up - $1300. By the sound of the estimates above, I got it cheap!
    Larry.
    '51 Series 1 80"
    '12 Defender 90
    Rovernaut Guest
    Quote Originally Posted by hiline View Post
    It would almost pay to hire a hoist, pull the engine out, probably easier than pulling the gearbox transfer case and replace the clutch, spend a couple of days and save a G.
