Thread: D90 / 4bt
    Apr 2007
    Central Coast NSW
    D90 / 4bt
    Now that's a bit different....and a torquey little bugger too
    Rover Hybrids Home Page
    two of those engines run the buck up fire system pumps at work... hmmmm
    does a 90 up really nicely like that and then goes and puts a but ugly roof rack like that on it
    should of put a hannable on it would of looked much meaner........
    Kiwiland
    Why do they make their engine mounts flat like that? Rubber works much better in shear than tension/compression.
    But a nice build. If you're LHD then a cummins will fit well and an Isuzu won't. If your RHD then an Isuzu's the go.
    St Helena,Melbourne
    4.28 MB
    What a big lump of engine that is, would weigh a bloody ton ! Rack is not bad - i have seen a lot worse.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Yinnar South, Vic
    Quote Originally Posted by Dougal View Post
    Why not tell late model manufacturers that, the went from angled mounts, to flat, falcons, commodores, etc
    Kiwiland
    Quote Originally Posted by rovercare View Post
    They're not using big inline 4's though.
