Results 1 to 10 of 21
Thread: Defender diff for 2 Door rangie
    May 2008
    Hey everyone,
    Ive got a 76 2door rangie with a 4.4, done all the work myself, i'll post photos asap. i went out over the past weekend and blew the rear diff. NOW i have 2 choices i can replace the original diff or as i have been instructed i can buy the defender diff and shorten the tail shaft. with this i plan on getting the arb locker as well. Strength is what im aiming for.
    Your thoughts?
    99.87 MB
    Thats fine if you want an anchor under the back. Have you considered other options?
    Slunnie
    May 2008
    maxi drive is not an option as they are out of business, and i want something i bit stronger so that an ARB would work without failing. i mean i can fix the problem i have cheaply but im looking for a long tearm fix with strength. The anchor thing are they that much heavier??? i mean my car is reletivley light as it is...
    Yinnar South, Vic
    The sals hangs down much lower, as its a bigger diff AND being a back loader, the cast housing is a grader blade
    I'll have a standard centre to get you going again, for a slab of Melbourne stubbies, if you in Vic somewhere close
    May 2008
    thanks for the info, is there a strong option for the long term though, and where in vic?? OH by the way i have 33's on the car does that change the grader option????
    Yinnar South, Vic
    Quote Originally Posted by 4.42doorrangie View Post
    Personally, I;d just fit an sirlocker to the rover centre with Hituff (maxi) Jacmac axles and be done with it
    Rangier Rover Guest
    Quote Originally Posted by rovercare View Post
    I'll second that. I've put sals under Rangies on 33s and Rover diff Maxied on 750x16 went round it
    99.87 MB
    I'd be doing the same also (and did). The diff isn't renowned for being strong but the locker and axles make a big big difference to the strength. The Salisbury on 31/32" tyres gives the same clearance as a Rover diff on 29's. A rover diff on 33's doesnt touch the ground often, a salisbury diff on 33's drags.
    Slunnie
    May 2008
    what and where do you get a sirlocker??? and are hituff the maxi axels??
    99.87 MB
    It's an ARB Airlocker from an ARB dealer.
    Maxi closed and Hi-Tough axles now manufacture the same axles. Probably even the same fella doing them.
    Slunnie
