Results 1 to 10 of 12
Thread: auto tranny
    Sunshine Coast, Qld
    auto tranny
    Hi,
    This is probably a silly question, but....how do you check the fluid in the gearbox? I've looked through the book and am beginning to think you don't have that option available.
    thanks in advance.
    St Helena,Melbourne
    4.28 MB
    There is a dipstick on the LH side of the engine near the firewall with a big orangeknob on it, on level ground with the engine/auto cold start the engine shift into nuetral and then check the level.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sunshine Coast, Qld
    Just had a look. Definately no big orange plug....like you'd expect.
    Could it be because it's a TD5? ....sorry forgot to mention earlier. My signature and avatar have gone..!!??
    VIC
    Quote Originally Posted by twigrx7 View Post
    In that case there is a level plug on the front of the oil pan where the dipstick should be
    Brisbane,some of the time.
    hi,you need to look further at checking the oil in a td5 auto.i think you have to check it while it is running at the level plug
    99.87 MB
    And also work it through all of the gears before opening the plug.
    You can fit the D1 auto pan which has the dipstick to the D2 if you really want.
    Slunnie
    Jul 2007
    Two Rocks, W.A.
    Thanks for asking that question Twigrx7...I was too embarrassed to!
    But I do have to ask why they would make it such a chore to check? Was that done for wading purposes, i.e. no water down the dipstick pipe?
    Mike
    '00 D2 Td5 'Alice'
    '03 V6 Freelander 'Phoebe'
    '04 Td4 Freelander 'Harry'
    May 2003
    On The Road
    the cynic in me says its so only the dealer will/can check it,,
    service it regularly,,
    check for leaks regularly(oil spots on flat carparks etc),,
    May 2003
    On The Road
    also,,
    ask Slunnie about checking the cooler for "obstructions"
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by 2 rocks View Post
    Mike
    If you are getting water down the dipstick tube, checking the fluid level is the least of your priorities - being able to swim is more important !
    1974 VW Kombi bus
