Results 1 to 10 of 11
Thread: engine in....
    Keilor East, Victoria
    engine in....
    I have struggled to get it in, everytime i tried it would stop with 1/2" to go.
    tonight, i undid the bolts, then, cranked the motor over by hand 1 rev per 2 turns of each bolt , took ages but now the motor is in , yippeee... now to do up the bell housing bolts, bolt in the engine mounts and i can start the mass reassembly
    also made another bench out of an old single bed frame and some chip board from my parents old kitchen
    to wind the motor in i used 8 x 3 1/2" all threaded bolts , air ratchet, single hex deep sock and lots of patience.
    i'll pop out later for photos :0
    Steve
    got it started last night... first time in 12 months woo hoo.
    it was a pain to connected the fuel line into the bowl... had an 11/16 lock nut setup that required a very skinny 11/16 spanner so a quick grind of an elcheap bunnings spanner saw that fixed.
    starter switch is RS and needed to be shorted to get going.. but it runs ok.
    now to make up an accellerator setup for the new carbie, rewire for alternator and tidy up the in dash wiring.
    Jun 2003
    Launceston, Tasmania
    Come on, where are the pics
    Counds like it is going well. A mate started a truck and drove it the other day. it was the first time it had moved under it's own power for 40 years!!
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Quote Originally Posted by Phoenix View Post
    New bench i made from a single bed frame and some chipboard from my parents kitchen handy having a second bench as the first one is always cluttered with tools and junk!
    Bolts used to pull the motor onto the gearbox
    Video camera is on charge to get footage of firing it up.... about a week before i can see if it can move under its own steam.
    Jobs for this week are:
    Finish last brake pipe
    replace clutch slave cyl and fit flex hose
    fit flex hose from rear axle to brake line.
    re-fit all interior / seats / floor
    rewire ignition
    rewire alternator (as it currently wired for generator)
    make up some why of getting the throttle connected
    JDNSW's Avatar
    Quote Originally Posted by srowlandson View Post
    Thanks for the pictures. And should we start running a book on how long it takes to get the new bench just as cluttered as the other? It seems you have already made a good start!
    Ease up, thats just he power tools used to build it on top and my box of air tools i was using at the time that get stored on the bottom shelf
    it is messy now though, with a 1/2 made brake line, flare tool kit all over the place and some other various hand tools. i do try to finish each session in the garage by putting all tools away though... I know my old man wished i did that when i was younger, we were forever in trouble for leaving tools laying around!!!
    darwin, nt
    You've got a six cylinder fan on your four cylinder! I thought they'd fit, just never tried it. It looks a bit bent. Check the blades aren't cracked (a bit of a habit I've heard) and the rivets aren't loose. I've also heard the 6 cyl fan is too big for the 4 cyl shroud. Nice project, though.
    Dan.
    69 2a 88" pet4, 74 3 109" pet4, 68 2b FC pet6.
    Quote Originally Posted by dandlandyman View Post
    Dan.
    thanks for the tip, i'll be refitting the radiator and shroud this week, i'll take a look. Worst case i can switch it for the original motors fan.
    JDNSW's Avatar
    You should see my shed! Mine makes yours look like a "clean room" for electronics. I have the same problem with putting things away, plus I keep getting stuff with nowhere really to put it.
    Oct 2003
    Godwin Beach Qld
    G'day srowlandson
    I would suggest that you reuse the standard 4 cylinder fan, either 4 bladed or the army 8 bladed, as the 5 bladed does have a habit of getting stress cracks and you don't want to know what the result of a blade going Ta Ta's at speed the 4 bladed stand 2.25 ltre fan does a very good job of cooling if the radiator still has it's shroud fitted, the 8 bladed military does drag a bit of power from the motor. the alternator is only Neg Earth and the regulated ones require 2 cables from them, and the non- reg ones, (early Holden bosch 35 amp jobbies require 3 wires), which go to the external alternator regulator.
    Nice job that you are doing
