Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: TDCi Defender Accessory thread
    dmdigital's Avatar
    Well we've got the Appreciation thread so I suppose I should start an accessories thread.
    Here's my list so far (some's done, some's on order, some is still a while off):
    Seat Covers - I've ordered a set of Melvill & Moon canvas seat covers from Exmoor Trim in the UK - Will post pic's when they arrive. Only canvas ones in Australia are MSA (Michelle's Sacs) or Escape Gear (from Sth Africa) and are more expensive.
    Snorkel About to order a Mantec Snorkel from the UK. I can get 2, yes 2, snorkels - including freight - from the UK for less than the price of one of these same new Mantec units in Australia. Other unit is for a friend in town.
    Bullbar - ordered the ARB. Already have a new Warn XDC 9.5t winch for it. I'll also be putting heavier springs in the front to compensate.
    Side steps - Her's and fitted
    Tow kit - OEM fitted and well used
    Anderson plug - also fitted
    Rear wheel carrier - about to order, going to try and get a Mantec unit or similar, also need to talk to Troutbeck - don't know if Len does one for post 02 models. If all else fails I'll get the Bearmach like on my other Defender.
    Steering guard - Have a Troutbeck plate to fit
    Diff guards - still to get these.
    Spotlights - will leave these until I can afford some HID's. Already have latching switch for genuine dash switch.
    Checkerplate - on the list, wing guards etc.
    UHF - I temporarily fitted an Icom IC-440 for the drive back. I haven't completed the installation yet, unit will go under cubby and speaker/display/mic (its all combined) will be the only bit on the dash.
    Engel plug - is fitted to the rear corner next to the speaker and back door.
    Dual batteries - Sniegy did a fantastic job of fitting this under the passengers seat. I must post some pictures of this!
    Brake controller - Redarc unit with remote head is fitted inside dashboard riser on driver's side. Panic button is one of the dash switches down by the A/C switch.
    Rubber matts - I'm slowly adding more protective rubber matting to the back area.
    Long range tank - undecided yet, may fit the 45L Front Runner unit sold by Opposite Lock.
    Water tank - again undecided, need to work on whether its required.
    Cargo barrier or load retention net - I must fit something, need to source this.
    Personalised plates - New plates on order.
    Definitely have to get some pic's as stuff goes on to the truck. Also I'm sure I've forgotten a few items.
    Perth, WA
    Hi dm_td5, Here's my stuff, (so far )
    ARB Winch Bar - I want to remount this as I can see it can go back 3 - 4 inches without too much trouble. I fitted "rangie red" springs from Les Richmond Automotive to take the extra weight.
    Warn 9.5XP Winch - Plasma rope on its way from the US, I also need to fit an isolator in the cab.
    ARB Compressor - Under the passengers seat.
    Rock Sliders - Bearmach ones, these needed a bit of modifing to fit.
    Quater panel protectors - Made them my self.
    UHFCB - Mounted on the side of the center console, (all the controls are on the handset)
    Scangauge II - Sits nicely on the steering collum
    Front diff guard - Bearmach on powder coated black, (the gold was just too bling!!)
    Bearmach Spare Wheel Carrier - Need modifing also
    Still to come:
    Lights - I really want HID's, but $$$$$!!
    Second Battery
    Drawers
    Long range fuel tank - Probably the OL one, but also $$$$!!
    Water tank - See above
    I think this vehicle will lead me to financial destitution!!!!
    Tim
    PS. dm_td5 would you mind telling me where you got the switch for the spot lights?? (I did ask my dealer and they said it was not possible to fit switches in the blank spaces....)
    dmdigital's Avatar
    Tim, switches are easy once pointed out. The back section is the same as on the D2 binnacle switches and the front fascia just unclips from the blanking piece and snaps on to the one from the Disco. A D2 cruise control switch is a latching switch for spotties (when I get them) and I used a D2 fog light (momentary switch) for the brake controller. The blanks can be gently eased out, just like on a D2.
    Jul 2003
    Spot Switch
    I bought a Defender front fog lamp switch from British Parts UK for $12 plus postage ($12)
    Part No YUG 000540LNF
    www.britishparts.co.uk
    I'm hoping there is a spare plug behind the dash on an unused loom that I can use. other wise I'll jury rig it.
    All the switches are moveable so I'll move the rear window switches to the passenger side of the fascia, move the rear fog to the left and place the spot switch where the rear fog is now.
    Mahn England
    Ex 300Tdi Disco:
    Jul 2003
    My ARB Bull Bar goes on tomorrow. Existing 170 Lightforce lights moved from the Disco this weekend.
    Wheel carrier, auxiliary tank and modified Safari snorkel from Opposite lock next week.
    Mahn England
    Ex 300Tdi Disco:
    Ellendale Tasmania.
    Just a heads up on seat covers, this mob In Front Camping Gear Really Odd Stuff & Car seat covers make canvas seat covers, they are in Australia.
    Rear D2 covers pictured
    REAR CANVAS CAR SEAT COVER FOR A DISCOVERY 2a (BOTH SECTIONS AND ARM REST)
    IDEAL FOR KEEP THE REAR SEATS CLEAN AND DRY WITH THIS WATERPROOF COVER
    Price:
    $275.00
    inc GST within Australia
    Also
    CANVAS CAR SEAT COVERS WATERPROOF WITH REAR POCKET
    MADE FROM AUSTRALIAN CANVAS
    COMES COMPLETE WITH A CANVAS BAG WHEN COVERS NOT IN USE
    HIGHBACK
    QTY 2 ( A PAIR)
    Price:
    $89.65
    Baz.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Adelaide Hills - SA
    Oh boy - that is a huge list of accessoried dm_td5!!
    You better add one more thing, a superb burglar alarm, to stop anyone running off with that lot of goodies
    Aug 2008
    Perth, WA
    37.36 MB
    Hi all,
    Our new Puma Defender is still being fitted out - just waiting for the bullbar, stereo and tinting so hopefully should be ready to pick up this week.
    Our accessory list for the Puma is as follows,
    Safari snorkel
    ARB bullbar
    sidesteps
    scrub bars
    towkit
    long range fuel tank (127L)
    dual batteries
    rear fridge plug
    cargo barrier
    bash plate
    spotlights
    personalised plates (organising now)
    window tinting
    Fusion car stereo (will swallow an iPod inside)
    spotlights
    to come later;
    UHF
    tunit chip (after warranty expires)
    diesel/gas conversion (after warranty expires)
    Will get some pics online after we collect our beastie.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by spudboy View Post
    Up here mate nobody locks their vehicles and some still don't even lock their houses!
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    City & Avoca
    Now the wallets getting emptier but here's whats on Daisy so far.
    Scorpion AC Bar (Rovacraft)
    Set of Roo Lights (with the blue bling lenses)
    Ironman Winch running B-Line synthetic
    Alloy Steering guard - Scorpion Racing (Rovacraft)
    Outback Roof Console (AR
    UHF and Gutter mounted Aerial
    Tree protector / rock sliders - Scorpion Racing (Rovacraft)
    Genuine Towpack
    Second Battery and cradle - Pirhana
    Anderson plug for Camper
    Secondary outlets under 2nd row seat for DVD player, Nintendo, what ever the kids take.
    Decent Rubber - Coopers STT
    Genuine TDCi Safari Snorkle - will hit stores soon production is about to start
    On Order:
    Diff Guards -
    Rear Corner Bars
    Light protectors
    Chequer Plate for Front guards
    On Wish list:
    Rear Locker,
    Cargo Barrier
    Draw System
    Evo Suspension Kit
    LRange Fuel Tank
    Spare Wheel carrier
    Time to enjoy it more
