Results 1 to 10 of 15
Thread: ARB BULLBAR MOD
    Oct 2008
    ARB BULLBAR MOD
    g,day all
    i have a range rover 1990 with a standard non winch arb bullbar
    i am wanting to put a winch into this bar spoke to some ****** at arb and he says the bar will not fit a winch and that i need to buy a winch bar
    is there a way that i can cut and weld in a winch plate to mount a winch into this bar or has any one done this before
    or maybe someone knows where i could get this modification done in the dandenong/cranbourne area
    all help appreciated
    thanks again
    shane
    G'day Shane
    did exactly that to my 90 RR with ARB non-winch bar. Just got a 6mm steel plate the width of the bar between the uprights and welded a return at the top (see pic) fitted Warn 8000 Lb winch and roller fairlead. Has worker well for 6 years with no distortion of the bar. Probably a bit over overkill in terms of strength and weight. I can send measurements if you need
    Nick
    Oct 2008
    thanks nick for the reply the measurement would be great at least i could get the steel plate organised without havin to pull the bar off yet
    but with this option are you bolting the winch straight on to the front bar (with plate) verticly yeah !
    thanks mate
    in the wild New England, NSW
    Quote Originally Posted by forget View Post
    thanks mate
    pulling the bar off is probably no big deal - just get a couple of strong young guys to take the weight ( support might be good too)
    Nick, I think a few of us would like your plate dimensions if you could post them here, thanks, Laurie
    99.87 MB
    You can buy the winch plates
    Here is the Tigerz11 one.
    THISWOTIDONOW!!!!
    Slunnie
    Oct 2008
    i spotted this but is is for a jeep bar
    this would be ok but i would rather some more support in the front section
    looking at this you would boltt the winch horizontal as per a normal winch bar
    but will look at anything though
    i got the pic from here
    Jeep Mounting Plate
    Oct 2008
    geez slunnie just what i was thinkin about!
    anyone had experince welding them in,
    what about the winch plate flexing any dramas?
    99.87 MB
    The low mount winches mount with the bolts going through the bottom of the winch plate. Only the fairlead or hawse goes onto the front.
    Slunnie
    Oct 2008
    mate i just looking at the page you posted and this link from within
    http://www.thiswotidonow.com/ebay/STEVESINSTALL.htm
    mate thanks i be givin em a call tomorrow
    might be workin nearby to them to yi-ha
    just lookin at this pic
    the problem i may have is the front vertical section of my bar is only the same height as a number plate 5 1/2inches it may be tight fit
    Somewhere else, QLD
    Try this - the bit about the bar mod is halfway down
    Inside a winch and upgrading a Disco bullbar.
