11th October 2008, 07:36 PM
disco 1, v8 getting a little to hot
went up duck creek rd today. and found that the disco temp was right up at top of temp gauge.
i assume this isnt normal i actually had to pull over as it was nearing the red.
can i run a extra fan or somthing to stop it getting so hot. ive heard from another bloke that its possible
its had a recent rad fluch with new coolant etc etc. and i know the twin fans are kicking in but it's not cooling quick enough,
any 1 got some ideas>? thanks
11th October 2008, 08:06 PM
I would say that you have an airlock in the system, especially since you mention that you have had a radiator flush.
Bleed the system and see how it goes, I wouldn't look at extra fans at this stage until you have ruled out the cooling system.
Edit : Apparently the gauges do show high temp if they are faulty, but I would still check the system for airlocks first.
Edit Edit : Forgot to mention as well that because these engines are ally, they have liners in them. If the engine gets too hot a liner can slip, which is bad. If it's getting that hot turn the engine off before it's too late
11th October 2008, 08:10 PM
ok i understand that, but this is the only time its happened, did a 250klm trip today and only got hot under a lot of load. ( up hill etc 4wding)
11th October 2008, 08:35 PM
#4
what's it like when you give it a good thrashing on road ?
11th October 2008, 08:37 PM
#5
the highest it gets ever on the road is half...........
11th October 2008, 09:49 PM
#6
I had a similar problem with mine when i put thermo's on it.It would over heat as soon as i put load on it.Went back to viscous coupling and no troubles.
11th October 2008, 09:54 PM
#7
my mech thinks the viscous thingy is playing up, well thats what he said today
