Results 1 to 10 of 30
Thread: Temperature spikes in 4BD1T
    SW of Geelong
    Ever since I fitted the 4BD1T to the County I have noticed the occasional spike in the water temp. What I mean is, most of the time the gauge sits on 80 - 82 where it should be, but occasionally it will suddenly (in a matter of about 30 secs) shoot up to approx 100. It happens under normal driving conditions. If I keep driving, the temp will slowly go back to normal ( in a matter of a minute or two)
    My first thought was air trapped in the system as it had been completely drained for the conversion. I thought I fixed it by installing a fitting on the thermo housing to top the water up from the highest point. (truck thermo housing doesn't have filler cap like the Landy one) This seemed to work as I didn't have a problem for a whole 8000 km outback trip.
    But anyway, it's started doing it again.
    There are no leaks in the system and it holds pressure for days and is clean.
    The thermo and O ring was brand new when I fitted the engine (about 25k ago), but it is not a genuine Isuzu thermo.......this is now the thing I suspect could be causing the problem, maybe sticking or something. Should I have listened to my mate who told me to " Make sure you fit a genuine thermo".
    I know the gauge is ok as I fitted an 'Engine watchdog' and this confirms the temp increase. Any thoughts ??
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Kiwiland
    Last time I was looking, I couldn't even find a non-genuine thermostat.
    I'd go there first.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    sounds like a thermostat to me, just because they are new dont mean they work okay..
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jul 2007
    Eyre Peninsula SA
    Rijidij
    I would look at getting a genuine thermostat form Isuzu - I paid something like $65.00 for thermostat and "O" ring. My 4BD1T tends to spike a bit in water temp on big hills and then gradually recovers - it could be that the thermostat is not fully open when the load comes on the engine which causes the spike in water temp - see my post on water temps - I have been thinking of fitting a larger radiator.
    Christopher
    Kingston, Tassie, OZ.
    Murray,
    I would definately go with the new genuine thermostat. Mine was sticking open, as I went down hills the temp would drop right off. When I replaced it, it still had the 1988 date stamp on it
    That means it had travelled 500,000+km.
    Anyhow,the new one is fine now, with my 3 row RRC radiator, it sits exactly half, even with towing and the A/C on etc.
    JC
    SW of Geelong
    Thanks guys,
    Like I said I should have listened to my mate who told me to " Make sure you fit a genuine thermo".
    A member on here has generously offered me a spare brand new thermo. It will be interesting to see if it makes the difference.
    It's so easy to fit a new thermo, it would be the first thing I try, but I thought I would pose the question just in case there had been any other issues with spiking.
    I had the V8 in the County for 13 years and whenever I had any hint of temp problems it was always the thermo.
    Cheers, Murray
    '56 SI Ute Cab
    SW of Geelong
    Took the County for a run today with a new genuine thermo fitted. It was only about a 50km trip, but all seems well so far. Probably need a longer, warmer drive to really test it out. The temp seemed more stable with the new thermo though.
    Visibly, the genuine thermo looks to be better quality than the non-gen one.
    Hopefully it's the end of the problem.
    '56 SI Ute Cab
    SW of Geelong
    I've had the Genuine thermo in for quite some time now and it has been much better, but it still spikes now and then. Most noticably, when I'm travelling at 100 kph it's all good, then I slow down to go through a small town and the temp will suddenly spike up to 100*. It only stays there for 10 or 20 seconds, then slowly goes back to 82* where it's supposed to be. It's also no problem while 4WDing in the bush at high or low RPM, even when working it hard up long steep hills. It never actually 'overheats'.
    I noticed it's losing water out the overflow hose from the pressure cap. On the trip we just did, 2 mornings in a row I put approximately 1.5 litres in to top it up.
    The rad cap is stamped with the numbers 16 and 110.......is this the correct cap ? It was a new one I got when I had the V8 in and still appears to be in good condition. Is the Isuzu supposed to have a different cap ?
    Cheers, Murray
    '56 SI Ute Cab
    Adelaide, SA
    Based on the symptoms, I'd say its likely to be a faulty pressure cap (i.e. it's not holding pressure)
    If you're losing coolant through the cap, either its not holding to its rated pressure, or you have air in the system.
    If its a V8 cap, it's rated to 16 psi. At this pressure, the boiling point of water is 121 degrees. If it didn't exceed 121 degrees, the pressurised coolant shouldn't boil (and there shouldn't be any loss).
    Alternatively, if the pressure cap doesn't hold ANY pressure, the coolant would start boiling at exactly 100 degrees, so the temperature would reach 100*C and then stay there while the coolant is boiling (explaining your coolant loss). If its holding some pressure it would go past 100*C, and how much past would depend on how much pressure the cap is holding.
    If your pressure cap tests OK, I would look for a split in the coolant reservoir, or a leak elsewhere in the system - (it would have to be one of the higher points in the system).
    I wouldn't worry about the temperature spiking for a short time after slowing down from 100km/h, especially if the system isn't holing pressure. => At high load the engine is producing plenty of heat, but at that speed, the airflow over the radiator gives it enough capacity to dissipate it. As the car slows down, the radiator has instantly lost some of its ability to transfer heat, while there's is heat temporarily stored in the engine block even after the engine stops producing it. The coolant temperature increases to a new equilibirum point until the heat stored in the block is dissipated, after which it goes back to normal temp as determined by the thermostat.
    It fits, I just hope its that simple.
    Bojan
    SW of Geelong
    Thanks Bojan,
    The system actually holds pressure even after sitting for days, so I don't think there is a leak anywhere. I will test the cap as you suggest. The fluid loss is deffinately out the overflow at the cap. Anyway, a cap is such a low cost item, it might be worth getting a new one.
    I've got the radiator from the truck my engine came from. I'll have a look at the rating on that cap just for interest.
    Can anyone tell me the rating for the pressure cap on a factory Isuzu 110 ?
    Cheers, Murray
    '56 SI Ute Cab
