View Poll Results: Which oil do you run with your ARB airlockers??
Voters
23. You may not vote on this poll
  • Standard 85/90 watt
    15 65.22%
  • LSD oil
    8 34.78%
Results 1 to 10 of 16
Thread: ARB airlocker diff oil?
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Hi all
    I know there has been alot of discussion on this topic but i can't find out which is the best oil to run with ARB airlockers, LSD oil or 85/90 (standard).
    So i thought i'd start a poll.
    CHEERS TIM.
    99.87 MB
    You wont need the LSD spec as it doesn't have clutchs in them..... well, they do have dogs if you want to call it a really really really course clutch.
    Slunnie
    I just run a Penrite hypoid gear oil... 85/90 from memory...
    (and back in the UK I just used the same grade in an agricultural hypoid type gear oil - as we had big drums of it)
    ps its not watt, its weight!
    Oct 2007
    Quote Originally Posted by Psimpson7 View Post
    I just noticed that, for some reason i had watt in my head
    Don't think i can edit a poll.
    TIM.
    Last edited by p38arover; 21st January 2009 at 01:00 AM. Reason: fix quote - but not spelling :)
    Feb 2005
    i use standard diff oil
    99.87 MB
    Quote Originally Posted by long stroke View Post
    Don't think i can edit a pole.
    TIM.
    Or the Poll.
    Slunnie
    Oct 2007
    Or the Poll.
    I'm not doing very well tonight
    NSW far north coast
    FWIW, ARB recommend a non LSD oil and this is the reason I was given.
    According to an ARB engineer on another board LSD fluids may contain abrasive friction modifiers that will abrade the 'O' ring.
    I called BS as no friction modifier I know of will do this and if they did, diff's would have failing pinion and axle seals all over the place, but he stuck to his guns...
    A blender I speak to confirmed what I thought.
    My opinion, FWIW is that either would be fine.
    Moruya Heads/Sth. Coast, NSW
    Why would you use LSD oil in a diff that's NOT LSD, Regards Frank.
    NSW far north coast
    Quote Originally Posted by Tank View Post
    Because you can.
    I just buy diff oil to suit the Patrol (80W-140 LSD) and so use it in the Sals too.
    Saves having another drum of oil in the shed.
