Results 1 to 10 of 14
Thread: Gearbox
    May 2009
    Launceston,Tasmania
    Gearbox
    G'day all,
    this my first post on this forum, so dont be to harsh.
    My problem is with my 86' classic gearbox, it seems a little to hard to motivatate it to change gears. I was wondering if a overhaul of the gearbox was a job the average bloke could do or if it was one i should **** off down to the garage. (its a 5 speed manual)
    not something you want to do if you've never done a gearbox before and/or dont have a manual.
    mike 90 RR Guest
    I would give it a oil change first .... might loosen it up
    Mike
    May 2009
    Launceston,Tasmania
    I have managed to get my hands on the workshop manual. It seems to be a pretty big job for a person to do without a decent workshop, so i might just give it an oil change and wait until i have the funds to get it done by a mechanic.
    Adelaide - Torrens Park
    I am running Castrol Syntrans in mine. Shifts better than ATF.
    Rangier Rover Guest
    Is it a LT77? Reverse to the left and up.
    May 2009
    Launceston,Tasmania
    I am not sure what model the gearbox is but reverse is to the left then up.
    That is the LT77. A bit renowned for being weak, but I haven't broken mine... yet .
    Avoca Beach
    Hard to change gears may be the clutch dragging because the hydraulics are buggered. This iss probably the most common and likely fault.
    Does it grind or just sort of refuse to go in?
    Grind is gearbox hard is usually clutch.
    Did it start relatively suddenly or after you changed oil?
    Regards Philip A
    Good call Philip. We are forgetting the simpler probs these days.
    DL
