could be....
once they start to go they last for ages (usually) and will survive with a lot more play than youve got.
It can be replaced with a single mass unit but other than race type applications IVe not heard anything advantageous to doing so other than the flywheel wont wear out and can be machined.
I suspect that, based on the few reports from people who have fitted them, that they will be harder on the front end of the gearbox than the dual mass unit and you might find yourself replacing the box more often but at this stage as the only people I know that have done this have put second hand boxes (the original box) back onto the new flywheel/clutch I'm only speculating.
Whats even more frustrating about it is if you happen to get a good one that lasts the life of your friction plate when you goto replace the friction plate you cant get the bugger ground so new clutch=new flywheel as well.
