Results 1 to 6 of 6
Thread: Will VPN allow access to file on Server (via mapped drive)?
    Adelaide Hills - SA
    Am pulling my hair out with this. SQL Server is my main expertise, so right out of my depth here.
    Anyway - I want someone in a remote office to have access to some files in a folder on my Windows 2008 Server, preferably via a mapped drive in Windows explorer. They are also running Windows 2008 server, btw.
    I have:
    o added the Role on the server for Remote Access Client & set it up with the defaults suggested for a VPN.
    o Set up the user as a local user
    o Allowed them dial in access
    o given the new user permission to the shared folder I want them to see
    o Set up the port forwarding on my router (via TCP 1723 and 47 (GRE))
    They can connect and authenticate, but nothing much else. I can see them connect via the RAC utility.
    They can't ping my server, even with Symantec turned off at both ends.
    They can't map a drive in explorer (trying \\MyServerName\ShareName).
    Is what I want to do do-able, or do I need something else apart from VPN set up?
    David
    Something else I just noticed: Windows Firewall with Advanced Security seems to be on. I would have thought Symantec was doing the firewall work......
    mikehzz Guest
    When I have done it, I have given the vpn connection a different network address (if the main network is 192.168.1.XXX I will set the vpn to hand out 192.168.25.XXX to each end of the connection for example) Then to connect to the share I type \\192.168.25.XXX\sharename
    I don't know if this helps but it was the only way it worked for me
    Mike
    Adelaide Hills - SA
    OK - thanks for that - will give it a try.
    I also turned off the Windows firewall but that made no difference.
    It is very frustrating to see the connection there, yet not be able to browse the hard drive
    If I do an IpConfig command on the server, I get this:
    Ethernet adapter Local Area Connection 3:
    Connection-specific DNS Suffix . :
    Link-local IPv6 Address . . . . . : fe80::f91e:826d:3cf3:62f7%13
    IPv4 Address. . . . . . . . . . . : 192.168.1.10
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    PPP adapter RAS (Dial In) Interface:
    IPv4 Address. . . . . . . . . . . : 192.168.1.51
    Subnet Mask . . . . . . . . . . . : 255.255.255.255
    Tunnel adapter Local Area Connection* 8:
    Media State . . . . . . . . . . . : Media disconnected
    Do the subnet masks have to be the same (i.e. one ends in .0 the other in .255)
    Jul 2008
    Cheltenham, Vic
    Focus on getting pinging working as your first step, if you can't ping you wont be able to map a drive since it needs the IP connectivity in place to work over.
    Agree that it'll be easier to troubleshoot the vpn connection if you put it on a different IP address range as it'll make it much clearer what traffic is to be sent over the VPN to the remote machine and make the routing much more simple.
    Al
    mikehzz Guest
    I just connected to mine and did an IPConfig on server and my laptop. The out put was
    Server IP Config
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : MAIL
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : Yes
    WINS Proxy Enabled. . . . . . . . : Yes
    PPP adapter RAS Server (Dial In) Interface:
    Description . . . . . . . . . . . : Internal RAS Server interface for dial in clients
    Dhcp Enabled. . . . . . . . . . . : No
    IP Address. . . . . . . . . . . . : 192.168.25.20
    Description . . . . . . . . . . . : AMD PCNET Family PCI Ethernet Adapter
    Physical Address. . . . . . . . . : 00-0C-29-50-8A-A2
    IP Address. . . . . . . . . . . . : 192.168.0.2
    Default Gateway . . . . . . . . . : 192.168.0.1
    DNS Servers . . . . . . . . . . . : 192.168.0.1
    Client IP Config
    Host Name . . . . . . . . . . . . : Mike640
    Primary Dns Suffix . . . . . . . : Rockend.local
    Node Type . . . . . . . . . . . . : Mixed
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    DNS Suffix Search List. . . . . . : Rockend.local
    Connection-specific DNS Suffix . : _
    Description . . . . . . . . . . . : Bluetooth Personal Area Network from TOSHIBA
    Physical Address. . . . . . . . . : 00-16-41-76-D9-35
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.20.3
    Default Gateway . . . . . . . . . : 192.168.20.1
    DHCP Server . . . . . . . . . . . : 192.168.20.1
    DNS Servers . . . . . . . . . . . : 203.2.193.67
    202.135.30.4
    Lease Obtained. . . . . . . . . . : Wednesday, 7 October 2009 13:33:20
    Lease Expires . . . . . . . . . . : Wednesday, 7 October 2009 14:32:44
    Ethernet adapter Local Area Connection:
    Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controller
    Physical Address. . . . . . . . . : 00-14-22-AB-E5-62
    Ethernet adapter Wireless Network Connection:
    Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
    Physical Address. . . . . . . . . : 00-13-02-A5-9B-37
    PPP adapter United Sports:
    Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
    Physical Address. . . . . . . . . : 00-53-45-00-00-00
    IP Address. . . . . . . . . . . . : 192.168.25.21
    Default Gateway . . . . . . . . . : 192.168.25.21
    I'm connected via iphone and bluetooth to the internet and using the internet as the transport.
    The relevent adapater is the ras at 192.168.25.20 on the server and the PPP at 192.168.25.21 on the client.
    I hope these figures help
    Mike
    Jun 2008
    McMinns Lagoon NT
    Did you do a group update of the active directory?
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
