Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: Asbestos
    MoveLater2 Asbestos
    Just a quick question, does anybody know if there is asbestos in the LR series 3 diff gasket?
    Douglas Park, NSW
    No answers yet.....
    Asbestos is usually used in gaskets where heat is involved so I would say not in the car of an axle/diff gasket.
    All the cars I've worked on from the 40s to the current times (that's the years of the cars - not me) don't use asbestos in gaskets in that area.
    Brisbane,some of the time.
    I will go along with Scouse
    If you really wanna know,you could always get it tested
    no, asbestos was only used in engine gaskets mainly the exhaust and the carby spacer gaskets.
    it was also used in brake linings and clutchs as well as the thermal insulation
    Re: Asbestos
    Thanks for the input guys - I get a little paranoid :s
    I didn't think the diff gasket would require asbestos - if I'm doing some work with asbestos gaskets (engine, exhaust) though, would an ordinary face mask be ok? I know it's not dangerous unless broken, but I'd like to take some precautions just on case...
    May 2009
    wimmera
    a mask is better then nothing.
    but if you have a sponge and water handy just wet it, when its wet the fiber's dont go airbourne.
    Water spray bottle is the go to wet it down with,also many masks have "do not use for asbestos" written on them.
    You will have to hunt around for the correct one.
    ChCh New Zealand
    I did a job recently where there were 'professional' asbestos removalists. I was told by them that the hype over asbestos was great for their business. The consensus of the group was if general common sense was carried out, they'd be out of work. The only real concern for them asbestos wise was when asbestos had been used to lag plumbing pipes.
    Yinnar South, Vic
    Quote Originally Posted by Siska View Post
    Yep, Asbestos lagging, my old man tells me about how they used to have asbestos ball fights, like snow balls, with the lagging when he was an apprentice, my uncle only just recently died from mesothelioma
    He was also telling me, when he first heard of it in the SEC they showed a "safety video" in about 1970-71, he said it was an american film, and being into cars, had a few questions as to why the cars in the film were from the mid 50's
    Yinnar South, Vic
    Oh, I doubt it would be, as you really can tell an asbestos gasket in comparison to a composite, but if you want piece of mind, the best method is to spray it down, with CRC, penetrine or the like on removal, will prevent airborne particles, then double bag it, ideally you'd put it in an asbestos dump, but like most of it, it'll end up in landfill
