Results 1 to 3 of 3
Thread: 1952 S1 gearbox jumping out of 2nd
    Dec 2008
    australia
    Exclamation 1952 S1 gearbox jumping out of 2nd
    Hi there,
    My series one 1952 is jumping out of 2nd gear, first stays in ok, third stays in so does top. I have been told that it is caused by a small 50cent broken spring on a shaft? it it difficult to repair with out taking out the gearbox?
    Nov 2006
    Wollongong NSW
    Not realy. Thes pring plates are in the syncro hub on 3rd /4 gear
    Sounds like too mutch end float. Try tighening the special nut at the rear
    of the main shaft. access through the PTO cover.............
    JDNSW's Avatar
    Possibly the spring on the detent ball on the first/second selector shaft, and also it is possible that the stop for the second gear selector has come loose.
    Also possible, but unlikely, that the symptom is due to extreme wear on the second gear dog, or, a bit more likely, the partial collapse of any of the three bearings that align the mainshaft.
