Results 1 to 10 of 16
Thread: MY12 110 Puma Height??
    Mar 2012
    Adelaide, SA
    I am purchasing a MY12 110 Puma and would prefer to keep it under cover in the garage. I am concerned however that it won't fit height wise!
    My garage door height is 2090 mm. The brochure gives 2021 to 2182 mm depending on suspension and tyres. Its either going to be bloody close or not fit!
    I will have standard 110 suspension with Goodyear 235/85R16 MT/R tyres and the 7 seat option giving a little more weight in the back. Anyone have a similar set up and can give me a height? Will I fit ??
    Central Coast NSW
    Mine is a 2008SVX, was a 7 seater, had 235/85x16, 2" lift on the front to compensate for the bull bar and winch, actual lift about 35mm. Stock rear springs with Polybags
    Rear height was 2050mm, it fitted with about 50mm to spare.
    Drive way runs up hill to the garage door and that small difference means that I cant reverse in.
    Now has 285/75x16 and it is sooo sooo close, but it still fits
    May 2012
    Perth, Northern Suburbs
    Mine fits just but means i can't leave a roofrack on permanently!
    Mar 2012
    Adelaide, SA
    Quote Originally Posted by Drover View Post
    Thanks Drover. Given your specs I have 40mm to spare and also a sloping driveway. You have given me hope. Only time will tell.
    Mar 2012
    Adelaide, SA
    Quote Originally Posted by BigBlueOne View Post
    Blue, do you have a measure on the height of your garage?
    Central Coast NSW
    X 2 mine spends most of its time leaning against the garage wall.....
    May 2012
    Glenn i will get back to you with the measurement mate, have to go to work.
    Nov 2010
    Hi Glenn,
    I got a defender 90 MY10 and when i first purchased it i was scare to park it in any garage or shopping centre.
    But if you have the stock suspension and shocks you should fit in anything at 2.05m high
    i got a windcheetah roof racks on my car and it fits under 2.1m
    when i get a chance i'll take some photo and post it for you.
    P.S. be mindful this is driving in a level surface....it'll be different it you are entering from a slope surface
    Mar 2012
    Adelaide, SA
    Quote Originally Posted by sumosmurf76 View Post
    Thanks Sumo. Was looking at the windcheetah roof rack as well but I will be happy just to get the car in the garage and mount a roof rack when required.
    Perth, WA
    My 110 is 2050mm at the back. My garage door is 2060mm..........
