Results 1 to 10 of 30
Thread: Water pumps!!!!!
    schuy1 Guest
    Water pumps!!!!!
    Well, Decided yesterday that I could not put of the inevitable any longer. The weep from the TD5's pump was growing . So into it and man! what a learning curve about hidden bolts,nuts and just how tight a 40nm bolt is after 225000Ks but I prevailed, cleaned, replaced , polished and buffed, well not the last 2 Refilled the coolant and retired for a coffee
    Returned to finish off..........and hang on , whats that water.......? Drip dripping from the weep hole again! Checked and yes thats where its coming from! Sooooo I felt like doing a Henry VIII on it but restrained me self partly as that is a bigger job and dismantled it ALL again! The new spanker of a pump is faulty!! water is making its way out the weep hole in it. So a days work for nought!
    So replacement due on Friday,Tomorrow being ANZAC . And I was planning on being in Millmerran for the weekend. Gonna be dang tight schedule now!
    Just goes to show Murphy is alive and well! Oh and Eurospares? Dont touch! Bit hard when that was all I had though......
    Cheers Scott
    May 2009
    Tatura, Vic
    Scott. What a pain in the arse. How long did it take you? Obviously you will do it a lot quicker second time.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    schuy1 Guest
    About 6hrs start to finish I think, But Im not a fast worker I just potter along when its something I have not done b4 and clean stuff and such and because everything is so tight! I had it all off in like an hour 2nd time though.
    Cheers Scott
    Sep 2010
    Narrabri
    oh well...
    On the bright side it didn't let go halfway to Millmerran....I replaced my pump with an aftermarket recently and redid less then 10K later with a genuine for the same reason....I know the feeling
    Willis
    schuy1 Guest
    Yes thankful for small mercy And the replacements replacement is a genuine this time! Does cost more but saves in the long run I think.
    Cheers Scott
    Dec 2010
    Brisbane Bayside
    Wheres that bloke from Overload Offroad Spares talking up his crappy after market pumps in previous posts now??..
    I was caught once too got only 10000km out of a non genuine pump. I won't do it again . Go genuine..
    Oct 2010
    Caloundra
    Quote Originally Posted by schuy1 View Post
    Divorce the Disco or behead it?
    schuy1 Guest
    Quote Originally Posted by BIG O View Post
    Yes, although I did not get it off him but off another "forest Glen" mob and was assured they give a good run!! Having said that I have had really good runs out of aftermarket pumps on the series and on holdens and falcons, just I think now a days the workmanship of the aftermarket brigade has taken a nosedive ahead of profits!
    Quote Originally Posted by Pinelli View Post
    HeHe the beheading bit! But as I said, that involves more work!
    and you r the only 1 to pick up on that ref!
    Cheers Scott
    Dec 2010
    Brisbane Bayside
    Not good ..the "forest Glen " mob should know by now..that's where I got my short life ! replacement pump from too. That's bad if they're still saying they are okay to use.
    schuy1 Guest
    Hmm , Maybe Im not the only 1 who thinks they may be taking their eye off the ball a little lately.............
