Results 1 to 10 of 25
Thread: Does the number 5 trailer have to be reg'd?
    Sep 2014
    hi Guys,
    bit of a general question, does the number 5 trailer have to be reg'd? or is it sufficient enough to have the same number plate as the Vehicle towing it? I was told it might n0t have to be reg'd because it falls within size limits in Vic. Thoughts?
    Western Victoria
    I always thought they were too heavy (over 200kg empty).
    https://www.vicroads.vic.gov.au/regi...m-registration
    What are their size and weight?
    LandroverScott Guest
    Pretty sure Mick is correct, they weigh over 300kg from memory
    regards
    Aug 2010
    Sunbury, VIC
    In Vic, as mentioned - yes. Same as my itty bitty Sankey has to be because it actually has some decent steel in it and weighs over 200Kg. My little Sankey came in at over 400Kg empty. But for $24 a year, it's not the end of the world. It just needs working lights, a VIN or serial number that identifies it, and have roadworthy tyres and it will pass for rego.
    And if you ever want to take it interstate you are already sorted. NSW doesn't take too kindly to Vic's with unregistered 6x4's in their state. Far easier just to have it registered.
    Irymple, Victoria, Australia
    Interestingly in those Vic Roads regulations it states may have "limited TAC cover"
    A good reason to spend the thirty or forty bucks and have trailers registered.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by bacicat View Post
    IIRC the No5 are 370kg (making only 380kg legal payload).
    The Sankey although shorter in the drawbar than the No5 have the significant advantage of brakes so can have a payload at least 500kg and probably more.
    Aug 2010
    Sunbury, VIC
    Yep, good for 750Kg in the back. Has a GVM of 1,150Kg. Not bad for its size. I've had about 1/2 tonne in mine and it was sitting pretty at that.
    Apr 2013
    NSW, Sydney
    Sadly, no general use trailer registration exemptions in NSW
    Sep 2014
    Thumbs up
    Thanks All,
    I Figured it would be, I don't own one myself but I have a friend who owns one and is considering putting it on his club rego (same as his perente) which means I don't think I would be able to tow it behind my full reg'd Perente. Oh well, guess I'll just have to buy one!
    Western Victoria
    How much is a trailer on club rego? It's under $60 on full.
