Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Rowdy - 66 SIIa Build
    Jan 2015
    Hi Guys
    I've had my eye on the below vehicle. It's currently located in Perth and was hoping someone on here knew something about it?
    It seems in pretty good nick and has a holden 202 red motor in it.
    Also, if you look at the last 2 images the doors do not line up at the top and it's the same on both sides. Any clues on this and ideas on what new doors would cost me if it came to that??
    Cheers guys, I appreciate your input.
    Last edited by Mick_Marsh; 4th January 2016 at 12:40 PM. Reason: Title change at request from OP
    Jan 2015
    Well my teeth are now a little sore as I "bit the bullet" and bought this little thing!! 😆
    It is getting dropped off at the depot in Perth in the next 48 hours and will spend the next 2 weeks making its way here to Brisbane!
    I am going over seas (NZ) for 6 weeks from the 1st of Feb so hopefully it arrives with enough time for a few laps around the block prior to my departure.
    Busy times ahead....
    Stu.
    Bentleigh 3204
    The Door tops are adjustable .........usually by taking them off and bending the bolts slightly
    Apr 2011
    Wandong,Victoria,Australia
    Hi Stu,
    Nice looking unit - I have no doubt that you will love your new arrival!
    As for the doors - it could be almost anything, but the good news is that there is a bit of adjustment possible with the doors.
    There are 4 hinges (2 on the door bottoms and 2 on the door tops) and you can adjust these plus use washers as spacers as well.
    The door tops bolt (2 bolts) to the door bottoms, with a rubber strip between. So you can play around and adjust that as well.
    The door top sections - which are almost ALWAYS rusted. The bottoms can also rust. There are repair parts available depending on how bad the rust is - and your skills!
    You can by replacement tops and bottoms new - or source them second hand units. The Ho Hars on here sell second hand parts.
    Remembering that it's an old car - and a Land Rover at that - so the doors will never line up perfectly!!!
    Oh - and Welcome to the Forum.
    Tom
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Jan 2015
    Cheers guys!
    I thought this would be the case with the door uppers and it's good to know it 'could' be an easy fix.
    I'm sure there will be many more surprises awaiting me when it arrives so I'm sure I will have many questions.
    Thanks for the I found guys.
    Nov 2011
    My drivers door does that. I tried the easy 'bend over a piece of wood' trick which worked for a while, but it got worse again. turns out the metal in the door top was so thin due to corrosion it just ended up splitting.
    I'm currently in 2 minds whether or not just to get a new door top, or weld in a new section of steel. Probably won't know til I cut into it.
    Jan 2015
    Its one of those things I too will just have to work out whwn it finally arrives.
    Its finally at the teansport yard in Perth and should be here in 14 days... Unfortunately I am going to New Zealand for 6 weeks. Im sure I will be having too much fun to really care though!!
    Cheers for sharing your experience Ozdunc
    May 2008
    Bundaberg Qld
    Aftermarket replacement doortops are readily available. I have "Rocky Mountain" aluminium ones on one of my Series 3's. A bit $$, but totally transforms the driving experience.
    Rocky Mountain Land Rover Doortops RMG010
    Gold Coast QLD
    Talk to FWD at yerongpilly, they might still have some bits and pieces there, but if not, call the ho hars, I can give you their phone number if you need it. Harry has a literal shedload of stuff and they are great people (like all us series people ) welcome to the dark side, once the bug bites your under its spell for life
    Cheers Ian
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    Logan Village area S.E. QLD
    FWD don't do the rocky mountain door tops any more. but as ezyrama has said we have a **** load of parts here for the series enthusiasts
    Mrs hh
    Series Landy Rescue
    Our FB Page..
