Results 1 to 10 of 28
Thread: backing plates on brake rotors....
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I'm just wondering how important or critical others may think these plates are?
    My RH front cracked at every mounting screw about 18mths and I removed it.
    The two rears have both cracked on two places and I'm about to remove them in 15mins time.
    The LH front is still secure.
    Had no problems in two big trips with the RH front removed.
    Just wondering about their necessity.
    May 2013
    Brighton, Victoria
    I've done the same, but have read that the rotors and pads will suffer in sand driving. Seems the backing plate keeps out the sand
    Apr 2010
    South Melbourne
    Just buy new ones and use big washers to spread the forces to prevent them cracking again.
    Avoca Beach
    I welded mine on my RRC. Always rear left that goes first.
    Even with my chook poo welding it held for many years.
    Regards Philip A
    Brisbane,some of the time.
    Quote Originally Posted by carldjohnston View Post
    Exactly,they also help to keep out the dirt and dust on dirt roads.
    Jan 2011
    Gippsland
    I ditched my rear ones years ago and no ill effects since then - and think about it, reallly you don't need or use brakes when sand driving eh! and lets not mention mud driving. Ditch 'em, it's all scare mongering.
    http://www.aulro.com/afvb/discovery-...ml#post1652482
    onebob
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Feb 2013
    Sunshine Coast
    All of mine are removed after a wet trip up at the Cape. The area between the backing plates and the rotors filled with rocky mud. The mud dried out and fell away but the rocks remained wedged in there and very quickly wore huge grooves into the rotors.
    If I ever get another 4x4 with them on, ripping them off will be my first job.
    Jan 2011
    Gippsland
    Quote Originally Posted by Dervish View Post
    ....that was my experience although my rotors didn't sustain damage.
    onebob
    LROCV member #131
    Adelaide
    I have refitted new shields, with bigger washers (after removing the cracked originals some years ago.) The D2 hub and ABS sensor are exposed without the shield...
    No apparent ill effects until we were in the middle of the NT. This countryside is pretty rocky. A stone lodged between the inside of the rotor and ABS sensor, cracking it. Frequent 3 amigos for 2000km until I caught up with the replacement sent to Broome.
    I can see the point about mud and rocks, I dont get to drive mud all that often. Mine are staying.
    Jason.
    Apr 2012
    Orange, NSW
    Quote Originally Posted by onebob View Post
    onebob
    You might not press the pedal but the brakes are still working, how do you think ETC works?!
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
