Results 1 to 10 of 30
Thread: ANYONE KNOW WHAT THE HELL THIS IS???
    Nov 2014
    Northern NSW
    Hey guys, so I'm stripping the interior and cleaning up the truck in my time off, insulating it and all that. So im under the drivers seat and im finally going to untangle the mess that was there when I bought it, reline it, insulate etc etc.. I had a dual battery setup on the other side that was shot and also it was setup with trailer brake etc..
    so what is this thing? I though it was just a trailer brake setup, as by the way it was just hacked into the ECU, i did a search on the part number SAAB FRCRTD5 and it comes up with a lot of pages in foreign languages but not a whole lot else, i've narrowed it down ( i think) to either an aftermarket ABS controller, a diesel performance setup - dimsport in Europe do this with this part number, or it's some sort of trailer brake attachment.
    Any ideas guys.... FYI ive had a persistent surging problem for a loooong time now. Ive literally chased everything, wastegates, turbo hoses, thermostats, handbrakes, alternators - just redid the fuel pump and harmonic balancer too as they needed doing... I'm wondering if my NNN ECU upgrade from Jose is having conflict with what could be some sort of diesel tuning setup maybe? it has a little control box with a simple on/off switch and a blue light that comes on.. The car was sluggish as hell when i got it... joses map and allisports intercooler helped that out, but i have joses turbo coming soon and want to sort this out..
    ANY IDEAS???
    thanks again guys.
    jesse
    Last edited by blackapache; 8th January 2016 at 01:01 PM. Reason: forgot attachments
    Nov 2014
    Northern NSW
    here's the photos
    Sep 2012
    Adelaide Hills
    ejection seat button?
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Apr 2012
    Orange, NSW
    I've seen something like that before, it seems to have escaped me now...
    But I think it could be a clip on tuning box?
    Paging Tombie...
    Sent from my HTC One using AULRO mobile app
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Feb 2014
    The first photo's look like some type of ECU chip.
    If it is it could account for your performance issues.
    Does the light come on when you push the brake pedal?
    If it does then it could be a brake controller.
    You could also check this by attaching a voltmeter between pin no 5 (service brake) and earth on the trailer plug.
    If you get voltage across these two when you push the brake it means that the trailer brake is working.
    Alternatively it could be a combination of both!
    Best bet IMO is to rip the whole lot out, go back to the standard set up and start again.
    Good luck!!
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Aug 2010
    Sunbury, VIC
    What ever it is, with that many scotch locks, it's one heck of a dodgy installation. As suggested by others, I'd rip the whole lot out.
    Dopey Guest
    Would it be a BAS fixed limit boost box?
    Mike.
    What it is, is worthy of me extending my expletive range...
    Get it out, reterninate the harness plugs correctly and do it right. Its such utterly crap install work Im not even going to waste the bandwidth to see the full size pictures. Assuming the quality of the components is better than the quality of the install work (which isnt saying much) its probably still not up to par with other stuff you can obtain and I'll just shortcut the list here
    traxide Dual Battery System (Drivesafe on here)
    Tombies Remaps (was Tombie2 last time he was here) (IF you already have a remapped ECU then you dont need this unless your map is buggy)
    A tekonsha trailer brake controller (alko suppliers)
    Suspension stuff for your new springs/shocks (the mates rates kit)
    MR automotive for NIRTS parts and Roverlord via the forum for routine/service parts
    Daves interesting things (Incisor) for your workshop manual/Rave CD
    and AULRO for short notice help and general comraderie
    Various forum users taglines for chuckles and inspiration
    And P38Rover if you need to spell something.
    Western Victoria
    That would be "p38arover".
    Colin6 Guest
    I am new to this forum so please forgive me if I commit an offence, or get it completely wrong and it makes no sense. The wires it is attached to look to be the injector wires, yellow with a coloured trace. This may explain the performance issues if it is feeding power in. If you remove it check the wires carefully as some of the strands will have been cut by the connectors.
