Results 1 to 10 of 34
Thread: Discovery 2 Dual Battery
    Jul 2016
    Australia
    Hi, in My D2 i have an dual battery setup from the previous owner and the battery isolator isnt working correctly, so i want to know what should i look for in an solution? Its all connected well and charges but doesnt isolate it,
    Also there seems to be and fuse running from the box out and then its cut off so i dont know whats that for.
    Any help would be good
    Canberra, Australia
    There are a great number of different "isolators" available, a photo of the installation would help us.....
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Jul 2016
    Australia
    True, but its all good now its worked out
    Jun 2016
    wa perth
    the isolator /solenoid may have been bypassed
    so both battery's are hooked up full time
    if its one of those digital things allow time for it to kick in and out
    May 2009
    Tatura, Vic
    If you need a new isolator, get one from Tim at Traxide.
    In my opinion, you can't beat them
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2015
    Williamstown, Victoria
    Quote Originally Posted by d2dave View Post
    I've had a Traxide SC80 for about 6 years. A wonderful bit of kit. Why people use a DC - DC chargers is beyond me.
    Build date 11th Oct 2003
    LROCV #1410
    Jul 2009
    Hobart
    Quote Originally Posted by Bohica View Post
    Hi,
    A Li battery has a different charging profile, so a dc-dc is needed to get a full charge in to it.
    May 2009
    Tatura, Vic
    Quote Originally Posted by austastar View Post
    Hi,
    There is a little more to it. A lead acid battery will only receive the amount of charge that it wants.
    When flat it will take a large amount, but as it becomes charged the amount of current that it receives tappers off, reasonably fast.
    A Lithium on the other hand, regardless of state of charge, will take what ever you throw at it.
    As an example. I have a lithium battery which has 190 AH capacity. Lets say I use 150 amps whilst camping.
    It is raining all day so my solar is not working. I decide to pack up and drive home. My D2 alternator is going to supply its full output to the battery, minus what the car needs.
    Lets say I leave at night. I don't know what the D2 needs in AH for night driving. I will just pick a number, lets say 30 amps. I think the D2 alternator is 120 amps
    This leaves 90 AH available for charging the lithium. The battery will accept this and it will take about an hour and a half to charge it.
    So your alternator will be outputting its full capacity for one and a half hours.
    Do this regularly and your alternator is not going to last very long.
    This is why I have to run a DC to DC charger. I have one that outputs 50 amps max. This protects my alternator.
    A DC to DC is also required for lead acid on late model cars that have a smart alternator.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jul 2009
    Hobart
    Hi,
    Yep, I have dialled the dc-dc to 20Amp for similar reasons. Since going Li with the house battery, I'm not chasing the last rays of sun with a solar panel.
    Nice!
    Jul 2009
    Hobart
    Edit
    The dc-dc charger stops charging the Li when it reaches full charge.
