Doubt if it's tyres - but very easy to check.
Swap the front left tyre out with another and see if the noise moves / changes.
Failing that - could be any one of a number of causes. I recently had a noise and some "grabbing" coming from the front end, which I originally suspected as either a wheel bearing or a CV joint. It was the centre diff lock engaging when it shouldn't have been, and the effects of diff "wind-up" were what I had been hearing. Managed to correct the problem using GAP IID Tool.
 e-diff, IID, LLAMS, ARB Summit bar & Intensities & twin compressor, Traxide, GOE sliders & guards,
