Results 1 to 10 of 29
Thread: Can you replace factory raised intake with a Safari Snorkel?
    Oct 2014
    Sorry if it has been posted before.
    have a factory raised air intake fitted. Does a Safari kit cover where these are fitted?
    1976 LR 90 Hybrid GONE
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1980'RRC Build in progress GOING
    Disco wrecking 93 & 94
    1993 RRC LSE
    Bangor, NSW
    The factory RAI has two nutserts installed above the air intake. The Safari requires there to be three holes drilled around the air intake - however, when the body is installed - it would cover the two nutsert holes. So I say it would fit.
    BTW, you require long, noodle-forearms to fit the Safari. The bolt that goes into the top left corner (closest to rear vision mirror) is a shocker to get to. I suggest paying someone to fit it!
    Rob
    Nov 2015
    Black Rock
    Why would you want to replace the Landrover RAI? It suits the vehicle better and can readily be sealed.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Oct 2014
    Quote Originally Posted by DieselLSE View Post
    It’s a bit ugly
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    The Safari is uglier, and required cutting a chunk out of the inner guard..
    IMO that’s a no from me!
    Oct 2014
    Ha each to their own
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    Jan 2015
    Sorry for slight hijack. I much prefer the look of the RAI to the Safari but would prefer it to be waterproof. I've had a look around but apart from discussions around the bend piece having holes which can be sealed and mention that the hose is not actually waterproof, I can't find a thread which outlines in detail how to waterproof the RAI (or is CaverD3's post it? DISCO3.CO.UK - View topic - Removable Snorkel) Ritter will do it - they will install it but don't sell a kit.
    Thanks,
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Northern Beaches Sydney NSW
    RAI vs Snorkel
    Each to their own, i have had both and fitted both myself. Must say the pity with the proper sealed Safari one is the cutting of the inner guard which put me off a subsequent purchase, the RAI is so much easier to fit and no cutting to the inner guard. I don't mind the look of the RAI but would prefer it to be a proper sealed unit. both have their benefits and shortfalls if only there was one unit that did both, sealed and was easy to install with no guard chopping.
    St Helena,Melbourne
    4.28 MB
    The airflow required some trimming of the inner guard which you dont see once fitted anyway , i dont plan on removing it either.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2009
    Wasn't there a discussion some years back about which unit flowed more air? My memoery might be failing me but I seam to remember that the Safari was given the nod as not only being waterproof standard but also for flowing more air.
    I have a Safari fitted to the D3 but reckon the RAI unit looks much better. The one thing that annoys me about the V8 D4 is it uses both air intakes.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
