Results 1 to 10 of 22
Thread: Injector extractor
    Dec 2020
    Diamond Creek, Vic
    Injector extractor
    Does anyone in Melbourne know where I can hire/buy a TDV6 injector extractor? The LR part number is 303-1127.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Injector extractor
    BSP in Campbellfield may have something - I borrowed a puller (well a modified injector top I could fit to my slide hammer) from them a while ago to pull a stubborn unit on my L332 but not sure if they lend/hire things out now or to who - but they are a super helpful bunch for any pump or injector question so worth the call IMO.
    St Helena,Melbourne
    1.13 MB
    Spray some WD40 or similar around the hole and leave overnight, mine came out without a hitch and considering yours has been apart too i'm surprised they wont come out easily.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2020
    Diamond Creek, Vic
    Thanks Nick, I'm taking the injectors out of the wreck and they don't look like they've been disturbed in a long time. The injectors are currently soaking in WD40 but I'm anticipating interesting times.
    josh.huber Guest
    If you have access to an old injector pipe, cut it, keep the nut. Weld the nut to a short length of chain. Weld the other end to a bolt you can screw into your slide hammer.
    The chain is helpful incase you don't pull perfectly square, it won't break the welds.
    I can send a photo later if you need
    Dec 2009
    Ranelagh, Tasmania
    You can try these guys Mechanics Tool Hire :: MTHire.com.au.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Dec 2020
    Diamond Creek, Vic
    Quote Originally Posted by Geedublya View Post
    Thanks, I tried them but they don't have this tool yet.
    josh.huber Guest
    Use long bolts and start it!!
    Dec 2020
    Diamond Creek, Vic
    Thanks for all the suggestions. I have sourced a tool from Endeavour Tools who sell through Burson. The tool should arrive in the next few days, meanwhile I'll continue soaking the injectors with WD40.
    Dec 2020
    Diamond Creek, Vic
    Quote Originally Posted by josh.huber View Post
    There's no way this machine will start any time soon. It's being stripped down as a donor parts car for my better machine.
