It provides a significant improvement.
Saw a thread some time ago about reducing the turning circle significantly on TD5 by purchasing new stoppers.
I'm about to purchase these parts and install but want some more feedback if anyone else has done this. I have 16" rims on my 00 disco.
thanks
More info?? What parts and is this for both Discos and Fenders or just Discos?
Ta
CraigE
2011 Discovery 4 TDV6
2009 DRZ400E Suzuki
2003 WK Holden Statesman
Departed
98 Ducati 900SS Gone & Missed
Facta Non Verba
there was a post just recently on this Craig,, part numbers, pricing, the works,,, just cant remember who the kind soul was,,,
edit; for disco2
edit2; 27mm down to 21mm or something like that---
'97 to '07. sold.![]()
For D2 the LR part number is FTC5151 you will need 2.
Thanks harlie
D2 Turning Circle
could've sworn there was a measurement,,,,
Call me tight - but I just cut mine down, took less than 10 min to remove, cut, finish, refit and paint.
did you take a measurement harlie?
Technical Bulletin 0026 CDS …. ref L8867bu …. & the 23mm lock stops. (manovering in tight spaces)
[FONT='Times New Roman','serif']Just a note to tell you all that ten minutes work can change the poor turning circle on the 2003 model to the same as a tdi. This is a service bulletin from Land rover to all Dealers stating that the 29mm streering lock stops can be changed for 23mm stops, thus improving the turning circle 9 inches for every mm taken off the stops.[/FONT]
[FONT='Times New Roman','serif']Cheers Aston[/FONT]
Anyone know if this mod can be fitted to a fender? my old girl could do with all the help she can get in the steering department.
